I never got the chance to hear @675430VME car with the jb4 but I can attest that the Mach 5 downpipe paired with his (I think is a custom) SS exhaust sounds extremely good for an i4. So much so that I also bought the downpipe.
That's great! 400 hp US version?
At crank, right? Thank's for sharing!
JB4 just arrived. Gonna mount it this week. Already installed the MACH5 GPF off, sports cat. It was a PITA to remove the original one..
400HP US version. Power figures are at the wheels. Hub dyno. Supposedly a stingy dyno that.
Yeah! Even with just the Mach5 downpipe, the sound at full throttle is already amazing — aggressive and sharp! And the pops during gear shifts and deceleration are absolutely out of this world. I can only imagine how insane it would sound with an upgraded rear muffler too.. hehe :-D
If noise is not a concern for you, I would go for a well design SS straight pipe. Cheapest, lightest, and sounds really badass through out the whole rpm. Some of the new straight pipes come with modified valve control so NO CEL as well.
Advice: Updated to firmware V3 Alpha, mobile app can no longer connect to the JB4 unit. Working with Burger to find a solution.
Thanks for the feedback! Using JB4 PRO with the BT dongle installed at JB4?
Which pipes come with the modified valve control?
You can do both as straight pipe or with muffler, either way you need a valve controller to bypass CEL.
Hey sorry for the beginner’s question but can fitting the JB4 threaten the health of the engine? I’m not planning anything crazy, no ethanol or something, just trying to compensate for those 40bhp that we in the EU were stolen.
Anything that changes anything can potentially threaten the health of the engine. Not limited to adjustments in fuel trim and ignition timing, piggybacks will also introduce additional wiring, which means increased risk of melting wires or disconnecting couplers that can result in damage. Understanding how the unit fools the stock ECU, and taking care of the wiring (heat, abrasion, tension, etc.) should reduce the risks of damage, but will never bring it down to zero.
Most piggyback users consider these risks vs their own risk appetites to decide. I thought that the JB4 harness was reasonably protected, if kept away from hot surfaces. (The OBD2 cable is another story)
I will write a comprehensive dedicated post on the methanol installation but just to update here are some prelimary results, pending more tuning and final dyno/road testing.
My setup currently:
Aerie sports cat and exhaust
new JB4 BT module and the newer JB4 Pro app
Snow Performance methanol pump
Burger Motorsports nozzle spraying into Weistec charge pipe
Using pump 91 (California) on the dyno at DRS my car baselined around ~360whp which is around 10% drivetrain loss on their dyno which normally reads about 10-15% lower than crank (that's normal). That's with a downpipe/sports cat and Aerie exhaust...pure stock might read 350/55 or so on this dyno. Using map 7 on the JB4 running one nozzle and 50/50 spray and some tuning with Terry's help remotely we ended up with 407whp. Doing the crank hp calculation that's around +50hp on pump 91 gas...which is kind of crazy.
I am getting a couple pre and post cat rich codes, from the methanol coming on little too early in transient throttle around 3-4k rpms, so we are doing some more testing with different JB4 settings for the methanol controller. I did also try map 2 using 93 gas and that map also feels very strong, super smooth and did not generate any codes. Previously before the JB4 I was getting codes from the Aerie sportscat, first the normal P0420 and then after the spacer, the sensor was too far away. Map 2 on my particular car seems to be a sweet spot so far.
While on the methanol map 7 the car has a ton of torque and in the canyons which is what I use this car for, I am running out of brakes pretty quickly - will be changing to more aggressive pads at some point.
Terry has been very helpful and responsive. If you are just going to do standard JB4 install and run map 2 with access to 93 gas don't hesitate...car runs very fast, tons of additional torque down lower where you want it, and kind of manic top end power. Once we get a real ecu crack and can add what the euro AMG A45S guys are running this car will be even more of a weapon. Big thumbs up it works really well. I'll write a dedicated methanol installation post once we finalize everything and I get lots more miles and figure out the best settings. My IAT's were ~10 degrees from ambient after running hard for a couple hours with repeated pulls and was consistent, the methanol works really well.
Oh also last note, the logging feature of the JB4 is super helpful. You can download your logs and throw it into ChatGPT/Claude/whatever you use and it will give you highly accurate descriptions of what's going on, how well your car is handling heat, AFR's, how much timing, etc. REALLY helpful. My Emira GPT is very impressed with the logs from map 2 and map 7 and gave me a couple recommendations which Terry echoed as well.
I won’t be the one installing the JB4, since I’m a noob plus the i4 looks to be much trickier than the v6. This means I will not have control over how the job is done. If fitting the piggyback means accepting the risk to see my engine fail without doing fancy things by a high chance, say 10-15%, then it’s a pass for me. If, instead, this means that the risk is higher by 1-5%, then it might be ok. I know that no one can give me those numbers, it’s just to clarify that yes, it’s clear to me that it will take some risk with it, but the real matter would be “to quantify the actual risk in order to properly evaluate it”. This is given by experience, which I don’t have.
For those with jb4: what is the headspace on the stock fueling system? Would ethanol mixes seem acceptable with tuning?
Edit: and on that note, I'm assuming the jb4 can only send demand it cannot control the port injection system itself. (I.e. turn it on at lower rpm)
As you say no one predicts the future, and just based on JB4 reviews and reddit it's reliable - it will expose weaknesses that are stressed if there are known prior issues but we have relatively new cars. "Engine fail" is a vague term and your percentages are too precise when there isn't a data set right now. My opinion (just 1 opinion) use as intended with the right fuel for the map you are using and you'll be fine. But like many, I tend to approach tuning with the assumption that I may have to replace the engine, transmission...whatever it is. Makes it more fun to enjoy than worry, it's money yes, but it's just a toy to give us pleasure so have fun with it. The increase in torque greatly affects the enjoyability of this car for the better, highly recommend.
KAZ thank you for the info. Look forward to your detailed report!
Car runs phenomenal on map 4. E3O map. I have a 55 gallon barrel in my garage. Torco race fuel is local and delivered a barrel for me. 17 gallons of torco E98 and three gallons of unleaded race gas ( unnecessary but why not ). I filled the rest with 91 octane shell gas. Our 91 usually has about 7-10 percent ethanol in it. Homebrew tests at E34. I could use pump ethanol but I trust the purity and consistency of Torco.
Reactions: Kaz
To answer your question the more HP you produce, the more strain you put on the engine and it's components. So with the JB4, map 1 would be the most conservative, and map 4 the most agressive.
If you install a JB4 you are most likely voiding the warranty of your engine and drivetrain. However you should study the Magnuson-Moss Warranty Act (MMWA), if you live in the USA. Other things like electronics would most likely still have warranty unless they determined to be caused by the JB4.
For those of you with the upgraded BT module using the JB4 Pro app (the free one):
1. I have a weird bug where the app won't connect unless the wheels are moving - I just connect when pulling out, but won't if the car is stationary
2. I'm not able to read or clear codes when the car is stationary and in accessory mode - might be because of no1 but the app seems connected after a drive, I can read codes when the app is active and engine running of course but it won't delete that way
you see anything weird like that?
that sounds super convenient! isn't the torque great? there's the cliche "I wish it came this way" but in this case it's true
This is the kind of feedback I was looking for, thanks! The thought of replacing the engine, transmission or whatever is not my cup of tea, I’d be constantly worried about time, money etc. I’ll be better off having some mods to the exhaust system (which if I’m not mistaken should be less harmful to the whole thing) or waiting for another car (2027?) to fulfill that desire.
