lion shf
Warranty should cover it
Forgot to mention "China focused role".Somewhere in Norwich ....
Lotus QA "since we got a bad batch of steering pump's, do you think we should hold off production until it is fixed or at least hold back the delivery"
Lotus Management " nah, just give them the car so we get paid, then we will take it in to repair under warranty. Keeps the line moving:"
Lotus QA "But that defeats the purpose of my job"
Two Days Later
Yes, nine weeks seems excessive for steering pump. @emirahl what was the reason you could not pick up the car earlier / was it infact fixed after a week or not?Nine weeks? If mine’s not back in a week I’m rejecting it and asking the DVLA to investigate why they are allowed to continue selling them.
There is a misunderstanding. The repair of the steering pump was one week and that happenend just last week.Yes, nine weeks seems excessive for steering pump. @emirahl what was the reason you could not pick up the car earlier / was it infact fixed after a week or not?
I hope all goes smoothly for you this coming Friday! Super Exciting!!There is a misunderstanding. The repair of the steering pump was one week and that happenend just last week.
The long time for hand over is just because it took the dealer seven weeks for preparing the car and licensing, although all documents were with him a long time ago. Now plus one week repair, plus another week for delivery (trailer) . Total nine weeks. However, so far I am fine, I had no time for it anyway. But now it need to arrive as I am running out of time soon. Six weeks road trip planned with the Emira, all hotels, ferry and so on booked.
I am positive to really get it this Friday. Than all would be good.
Update: had a new steering pump installed, lines bled and cleared. It was taken out for a test drive and power steering failed again after 2 miles
So currently waiting for the third steering pump to be fitted !!!
If that fails, I am at a loss as to what to do, and I may have to insist that Lotus give me a brand-new car or refund me my money
I wonder if any of the failed pumps were disassembled to determine the root cause.Update: had a new steering pump installed, lines bled and cleared. It was taken out for a test drive and power steering failed again after 2 miles
This is exactly right. A brand new pump, even if it's not a great quality pump, isn't going to fail within 2 miles of installation. I'd start doing a pressure test on the lines to see if there's a pinched line, or blockage of some kind. Maybe even a bit of debris got into the steering assembly the lines are feeding into.I'm told it's something with the lines that fails with these, not the pump.
Has this ever happened with Evoras?This is exactly right. A brand new pump, even if it's not a great quality pump, isn't going to fail within 2 miles of installation. I'd start doing a pressure test on the lines to see if there's a pinched line, or blockage of some kind. Maybe even a bit of debris got into the steering assembly the lines are feeding into.
One causes the other. If there's a blockage or a restriction in the hard lines due to a design flaw or installation flaw the power steering pump will quickly die due to increased load.I'm told it's something with the lines that fails with these, not the pump.
I’ve got to imagine the power steering lines are all new since it’s mostly a different car. It may use all the same main parts but all the plumbing is likely slightly different.Has this ever happened with Evoras?
Hopefully the line construction (pressure rating, ID, materials, etc) are similar.I’ve got to imagine the power steering lines are all new since it’s mostly a different car. It may use all the same main parts but all the plumbing is likely slightly different.
I’m sure they are but all it takes is one defect in manufacturing or installation to make a properly radiused line to be restricted.Hopefully the line construction (pressure rating, ID, materials, etc) are similar.
