switchlanez
There is some truth to "too much power for the streets." Such a simplification warrants some articulation. I interpret "for the streets" as 6 practical parameters where, to support more power, they start requiring compromise:
1. Weight
2. Size
3. Balance
4. Traction
5. Reliability
6. Cost
The C8 nails cost (#6) but at some compromise in the DCT's reliability (#5) which is a similar challenge Lotus faced with transmissions not supporting powers in excess of 430hp--and why the Radford 62-2 500hp and 600hp variants should have a DCT not offered in Lotuses to support those outputs. The C8 achieves balance (#3) and traction (#4) by simply rescaling size (#1) and weight (#2)--areas where more exotic marques compromise less by using more exotic packaging and materials costlier to both build and service/maintain (#6). I'm a fan of the C8's street presence but the more I see it on the street, the more I notice its absurd size and realize that's the trick in engineering a solution to support its performance within a budget.
V6 or i4 base Mustangs are more balanced to drive than the V8 Mustang GT. None are "too powerful" but it shows compromises are made in either direction. You start solving the compromises of those ~$30k-$35k Mustangs but throwing more than double that money priced into the Shelbys or Mach 1s. But then you start to question their values vs other options in that price range. And the cycle repeats up the sports car hierarchy.
Ultimately, you can solve all problems and never reach a point of "too much power" if parameter #6 (cost) is no object.
1. Weight
2. Size
3. Balance
4. Traction
5. Reliability
6. Cost
