Lowered My Emira
JuniorR
I threw on some Nitron Coilovers, posting since its seems very hard to find lowered Emiras!?
It looks good... Here in NJ we are getting more speed bumps and do not want to take a chance
on bottoming out my Emira...But does look good..
Looks great....assuming 10-15mm lowering? Are you going to space or stick with oem offset?
This is the absolut perfect amount of lowering the Emira. Very well done!
Which Nitron's did you go with? What are your driving impressions? Looks great!
Drives much better than stock, little stiffer but solid, I have also have dampers at the hardest setting.
Dropped about an 1" with front and back wheel spacers.
Originally had the GRP coilovers, shredded a CV boot with those.
Went with the basic Nitrons.
Yes, shredded one from the GRP system rubbing it, when installed was about 1/4 gap but gap closed after settled
interesting... hopefully it's not a normal thing. I'm sure GRP will respond if not.
I love coilovers, I had them on my last cars. The price for the Emira coiler overs are a bit high, since I mainly lowered for subtle looks. The ride quality I can imagine is impressive with coils.
What feels better about how it drives?
Did you have the car re-aligned back to stock settings after installing the Nitrons?
For everyone who shredded a boot with the GRP lowering sleeves, how much clearance did you have between the boot and the lowering cup?
1mm?
3mm?
More?
I'm on touring now but thinking of going the same setup as you. Would be great to have a more indepth review once your had a change to drive with comparision to standard. There seems to be little info out there in terms of Emira suspension setup.
Was that 1/4" gap distance between the boot and the locking nut, or between the boot and the spring purch?
Fwiw and before false info is spread here:
There is no possible way for the suspension to “settle” and decrease the static gap between the bottom spring perch and the CV boot. It’s a fixed mechanical setting. If the perch made contact or “shredded” a CV boot adequate clearance was not set initially.
When I installed the first set on my personal car I set it with a 1.5 turn gap (approx 2mm) and it barely touched the boot. I then gave it 2.5 turns/4mm and it has been problem free for 2750+ miles.
