Power Steering Pump Leak - Big Deal?
luciddaydream
Hi there
I took my car to a shop today to have it checked out.
They said my power steering pump has a leak.
Is this a known issue? What is usually the main issue? (ie entire thing replaced or just parts)
Is it an expensive fix?
I assume its covered under warranty.. but don't really want to take it to the dealer as they're far far away and I have a ton of mods that they probably would not love.
Thanks a ton
Hi there
Thanks a ton
It’s covered under warranty and an extremely common Emira failure, it’s all over the problems / issues forum. Even the very first delivered Emira had the power steering pump fail upon factory delivery.
Just had mine changed under warranty in the UK. It was picked up by the dealer at first service. He said it was ok to drive until replaced but it did get progressively noisier over time! I hope this helps
Yea, like KitKat said, this is extremely common. My power steering pump was changed at the dealer before the car was even delivered to me. I have no idea why this part is so prone to failure since it is a Toyota part.
@luciddaydream since they are far away I wonder if you could call them on the call to consult before bringing the car in. If they need to replace parts you'll probably need to come back after the parts come in.
I'm going to get my steering checked out in a few weeks. Nothing major, but not sure if it is 100% and given all the failures- I think it's worth a check, along with a few other very minor things.
