I'm going to be the weird one and say that this is a really interesting approach to a classic problem... digital bar tachs are somewhat non-ideal to use on track because there's a ton of the bar that's not actually used when in normal track driving rev ranges. At least with a round tach you can prioritize the important range across the top of the tach, but with a bar graph there's no natural way to highlight a range without adding clutter to the display. So this solution is interesting.
When trying to pick up information from your lower peripheral vision, the brain can process left-right color and motion ok but it needs to be relatively big motions to register well. Small fine movements are less visible if you aren't staring directly at the screen. So in this display, they've expanded the middle of the rev range to get more detail to the driver because the movements are over a greater space at the rpms that are being prioritized. Nobody drives at 2200rpm on track, so that range is deprioritized - the engine wakes up somewhere around 4k and redline is just below 7k, so that's the range they've stretched to get the longest "sweep" out of it that they could. The bits that are compressed at the left and right ends are areas that you wouldn't be using on track anyway, so why dedicate space.
It would have been helpful if they had actually highlighted the zone to show what they were doing, it would have improved the visual understanding of the scale change and show intentionality.
Something like this, I've accentuated the bar with dark blue in the stretched section from 4k to 7k:
