Speaker/Sub/Soundproofing Installation pics
Kaz
235
378
Seeing how the car is put together in these intricate matrix lego kit layers is fascinating. Just posting some initial photos as Johnny from https://www.calibredcustoms.com/ works on the car. He's awesome, just comes out to your home to install whatever you want, has done all my cars since...a long time ago lol. Lotus didn't spend a single ounce in unnecessary sound proofing weight lol...remove a panel and you just see the body panels, and hollow cavities that are no doubt echoing tire/road noise. Audio wise installing Focal components in the front doors and using the stock empty tweeter location, removing the rear sub and rear mid drivers and adding a powered 8" JL Microsub. I'll soon be at around 105lbs taken out of the car so will see where how much the sound proofing and audio gear adds - but already being down 100lbs is great.
Cool project! What are you planning on powering those speakers? OEM or will you be fitting an amp?
Reactions: Kaz
Going to try the stock amp, I actually don't listen to loud volume just looking for clarity and the floor noise to get lower to actually hear something lol. We'll try this out and will add amp if needed - good experiment to see if 6 1/2" component system and a powered sub is enough. We'll see...they are 2ohm so at least efficient - should be done by Sunday we'll know immediately.
fyi the number "2700" is handwritten all over all the panels everywhere...with a QR code and "Federal"
Excellent to hear!
ok so the experiment of using the stock amps lasted like 10 minutes...dont' do it. The signal is split between the tweeter and 4" to the stock drivers but there's no great way to configure any aftermarket speakers to them without having massive gap in frequency, nothing sounds right. Ran out and got an Audison SR4 300 4 channel, will bridge into two channel to drive the door components and no rear speakers except the sub. Basically do whatever KJWEmira already figured out lol. Ok we are at finishing door stage with outer panel and inner panel all covered in Soundskins Pro and all the removal and fabrication of the speaker mount.
If you don't mind me asking, how are you getting the full range high passed full range signal to feed the new amp?
I believe he took both front and rear signals into the Audison amp where it gets mixed - will confirm, he's tuning the components and sub right now
Actually scratch that he's using an Audio control line converter, all the high level goes in, the converter makes line levels to the amp
Any more pics and info on the install? How do you like it now? Did it lower the noise floor? How is the weight difference?
Thanks for any info.
Reactions: Kaz
oh it basically stopped here due to the fake engine noise signal the Emira (I4 AMG) puts out through the DSP. It's so loud the subwoofer basically rattles the windows when the engine is running. Right now I have the entire system disconnected because that fake engine/exhaust noise is so terrible. Lots of people trying to figure out how to defeat it, turn it off...might not be possible we're figuring out - I have a thread in the I4 section about this
oh but yes! the noise floor...that stuff did work really well definitely recommend doing the rear firewall and quarter areas as well as the double layers in the doors. Very noticeable reduction in road noise -
Thanks. I have the v6. So this would work for me. App the info
Reactions: Kaz
