It would depend how you go about removing the emblems. The best way I have found to remove stuck on emblems an not damage the paintwork is to use dental floss, as you can do it without actually touching the paintwork, but just using a sawing action on the adhesive foam tape. Then use a tar and glue remover, such as Autoglym Intensive Tar Remover, to remove the glue residue. Put some on a microfibre cloth and place over the glue reside to allow it to soak in for a while before gently wiping the residue away. You will need something like 3M VHB Double Sided Tape to re-appy the emblems laterDoes removing emblems / lettering like this run the risk of damaging a car's paint job? I'm thinking of that one post a while back where an installer managed to peel some of the Emira's paint off while removing a section of PPF.
