Sticking badges to center caps
Time2Fly
2024 DV/HY FE Owner
I have badges from @GRP to stick on my Signature Wheels center caps. The caps are flat and powdercoated. Is there anything else I need to do besides stick the badges on? Additional adhesive?
Just clean the surface with alcohol or similar and stick em!
If its cold where you are use a hair dryer or heat gun to warm them up for optimum adhesion.
Thanks, Greg.
Do you recommend a bead of silicone caulk around the inside edge to lock them in place? They have o rings which are pretty snug.
Thanks, Greg.
Not a bad idea on the backside of the caps to do that. Is will ensure they don’t pop loose until you want them to!
SV104? Stock size and offset? Weight savings?
SV104 +7 in the back and +5 in the front. Overall weight savings 23lbs iirc. It could have been another two pounds lighter but I went with the reinforcing ring.
How much longer before we see them on your car?
