Blackthought_
641
840
I survived Sonoma Raceway in the Emira.
My longer thoughts are in the description of the video, didn't want to spam here.
Had a few notable 'moments'.
Also the incorrect rear pads that EBC is cool with being incorrect, are building their lip in the rears - as expected. They don't look great and are at least somewhat falling apart - likely similar to the post above.
Getting after it! Nice. Always fun to see track vids of the Emira.
I did Sonoma the day after you with HOD and had similar inconsistent pedal feel throughout the day. Running EBC RP-1 pads and Castrol SRF fluid on stock rotors (V6 Manual, Sport with Cup 2s). I never got huge fade but the amount of travel was wildly inconsistent throughout the day and it wasn’t very confidence inspiring.
The RP-1s also have an aggressive initial bite which can upset the rear balance of the car if you hop on them too hard. Given the inconsistent amount of travel, I found myself fighting with this balance issue throughout the day.
I’m going to leave the RP-1s on for a bit to wear down some of the surface transfer and then have to figure out if I put the OEM pads back on (<1500 miles) or something else that produces less dust. @gcmak, are you happy with the EBC Reds for the street? It’s a weekend car so it mostly sees Highway 9 and don’t want to compromise too much street performance.
I was considering the RP 1 pads for an occasional track day. Do you recommend an alternative? Not a track junkie at all. but I also don’t want to ruin my new ceramic pads so am interested in what track pads make sense.
The RP-1s are the only ones I've tried on the Emira. I was happy with Pagid Yellows on my F80 M3, less happy with the Advance Friction Clubsport pads on my 992. Before that, I've had good experiences with PFC-01s on my E36 M3 and Hawk HT-10s on my Evo, but that was many years ago.
A comparison between 714 whp Nissan Nismo GTR and I4 turbo, at NOLA MSP. First let me say that I haven't had many laps the last few years at NOLA, (although I was the second car on track their first open track day) so times might be better with more track time. A couple months ago my best was 1:55 with the GTR, and then a few weeks ago 2:03 with the Emira. Emira Sport/oem Cup 2's. GTR Cup 2 325 square with Hawk DTC70/60. As I just got the Emira a few days before the track day, it had everything stock, fluid, pads, etc. In about 90 hot lap minutes I took the front pads down to around 15% left. Not a lot of fade but not a lot of great stopping power). When I get back to Florida this fall, I will install the best available at the time slotted front rotors, (and hopefully upgrade the rears too). I have a set of front EBC RP-X race pads for front. If I have to run the oem rear drilled rotors I will run something close to the oem rear pad to take it easy on the rotors. I hope that with improved brakes and getting more used to the Emira, I can get the lap times down around 2 minutes. I am also planning on hitting Barber MSP more, as the Emira should do better there than on a higher speed track like NOLA.
Just an opinion on doing a lot of mods. I have had 5 Nissan GTR's that I have tracked over the years since they came out. A couple of stock ones that retained the factory warranty and a few with mods that killed the warranty. The stock cars were trouble free but more mods meant more issues. I am replacing one of the GTR's with the Emira and, I look forward to not making all the trips back and forth to shops to fix yet another mechanical problem and to having a factory warranty. Hopefully my days of paying for a weekend at the track and then only getting a partial session or just a couple of sessions and then heading home will be history. Although my first track day with the Emira it coded something about fuel temp and after being cleared the first time it reappeared and went into limp mode. The track just puts a lot of strain on a car and brings out the worst unfortunately.
Thanks for sharing your feedback. Now I'm wondering if it's something else causing the inconsistent pedal travel/pressure. RP1, on paper, is a decent step up from the Blues that I wouldn't expect it to also vary. Less initial bite and being progressive is the type of pad I like, and on certain laps/parts of the track, the Blues deliver a familiar experience to a pad I've loved (CSG CP) to use on other cars (GR86, GR Supra, and G87 M2).
I never bought the REDs and glad I did not. I really do not like how EBC is OK with the rear pads not correctly sitting on the rear rotors. I am waiting on the Hawk Ceramic Pads - which do cost more but a few owners have reported they actually sit correctly on the rotors. I have an AutoX this weekend with the Emira and I cannot wait to get the Blue's off this car. I also really want to see if they've started to chunk/crack on the main surface (or not), and to re-measure the wear.
@kitkat has shared his thoughts on the EBC reds - he's also Bay Area local. He went from OEM > Red > OEM > Hawk Ceramics (maybe he put on the Reds again just before the Hawks). IIRC he said they're roughly the same - you can beat on em a bit but he's gotten them to fade on our back roads. Our hypothesis is the Hawks will end up remaining quiet because they sit on the rotor properly - whereas the Red and Blues tend to make noise.
I'll have to check on rear pad fitment for the RP-1s when I pull them off to see if it looks like what you shared earlier with the Blues. I don't remember it looking that way but wasn't paying close attention. I already ordered the Reds and will put them on to see how they feel.
I've tracked EBC RP1's once at this point, on fresh Castrol SRF at Laguna and I found the same as you guys are seeing; inconsistent pedal travel throughout the day. On my first track day, I tried EBC SR11 and those have WAY too high of a friction coefficient for this size of pad/rotor. Too much torque, so I stepped down to the RP1's and the initial bite is still too high, they're difficult to modulate, where the SR11's were impossible to modulate.
I'm coming from 16 years of tracking an Elise, where the limit to braking power was pad friction. In the Emira, it's clear that the brakes can easily overpower the tires. It's a different animal.
Agreed. I am able to engage ABS on command with OEM tires. I will re-eval when I move to 200TWs or lower.
PFC 15/08 is working well for me. Very good pedal feel, consistent travel, strong initial bite if that's your jam, but very good modulation/release characteristics. They didn't score rotors or crumble.
They squeal like a bus when cold, but I can drive them in the street without any performance issues (just to and from the track). The noise they make in the street is impressive though, so I just swap pads.
I don't have enough laps on them to assess pad life, but they seem "normal".
By the time I tracked my Elise, people had figured all this stuff out, but with the Emira, I'm experimenting. It's expensive to replace pads and tires and even suspensions after each track day :) My Emira came with touring suspension (I bought an orphan) and that was absolutely terrible at the track.
Agreed! I too have the touring suspension and there's just a lot more weight transfer than I prefer.
Bus stop chicanes feel like ages when you're waiting for the car to take a set or settle before putting in more input. That's really irritating when coming from a more focused/dedicated platform.
Waiting on your assessment of the Nitrons 😊
@OppositeLock, are you also running OEM rotors? I wonder if there's any weird buildup with high temp pads that's causing us these issues with an inconsistent pedal. But I also hear you on experimentation being expensive in terms of time and cost.
I'm on Sport suspension with Cup 2s so it feels pretty squarely a problem with the braking system.
Yes, I’m on OEM rotors but they don’t seem to have any weird deposits.
I’m tracking the Nitron Clubsports on May 5, I’ll have some feedback then. I didn’t get the axle lift since it’s quite expensive and I’m not lowering the car.
My next pad will likely be Ferodo DS 1.11. If it's still funky, then I'm just going to call it a quirk of the braking system setup. After my track day, the EBC blues make noise and the rubbing sounds starts in the rear almost immediately as I dip into the brake pedal, then followed by the fronts after pushing deeper into the pedal. I don't think this car - with stock width front rubber - needs a high friction pad. A high temperature pad perhaps. It was already a fine line of getting into the abs with the EBC blues.
Really spent some time trying to find a track bad that was better than the OEM pads, but not too aggressive as I’m not a track junkie. I looked at RP1s but looked like they still overwhelm the tires and probably overkill for me. EBC blue don’t seem to get good reviews. Called the dealer to get OEM pads and they were 1k!
So today I spoke to hawk customer service as I like they’re ceramic performance pads and they put me into the hawk ER1 brake pads. Parts numbers HB585D.660 and HB586D.660
Looks like it’s a step above OEM, has progressive braking, good pedal feel, can drive to and from the track, and most importantly high temp durability. The DTC 60 are discontinued I believe and the 70s and 80s are far too aggressive for me. Looking forward to how these do
