Adding a subwoofer
I'm in the process of replacing the audio system as it is terrible IMO for this level of car. What they call a sub is hilarious and weighs like a pound :-) I am buying the kit from kjwemira to install some proper speakers ... separate tweeter, 6.5', 5", low profile sub, and an amp. I can't give up the entire bench for a large sub so just adding a better quality sub along with the better speakers and sound dampening will improve the interior immensely.
Let us know what you end up installing.
Will do, something like a lowprofile 8" sub (i.e. Eton USB 8AR, Kicker hideway, etc), Audison amp, not sure which 6.5/5 yet ... need to before I get the kit
In my Elise I added this powered Sub (was a previous model but similar to this) and it made an enormous difference for less than £200. It looked messy as it just sat in the passenger footwell but worked effectively.
Where do you access the wiring to put something like this in? It’s a powered sub so connects straight to pre-outs and power, where would you find these in the Emira?
I've seen/heard a number of these in Elises/Exiges and they are a significant improvement. If anyone does this in the Emira, would love to know how much of a difference they make
The difference to the Elise was absolutely enormous, but then you’re not starting from much!
There may be room behind one of the seats in the Emira?! Just don’t know where you plug it in.
I am actually good with the fronts, once they break in there is a noticeable sound quality improvement. And many forget that the audio source is the biggest factor. Stream from low rez like Pandora and it sounds like crap. Go high rez like Qobuz and Tidal and it is a very different experience.
I am also aligned with many that the bass is boomy sometimes and nonexistent other times. This is usually a resonant frequency issue, so my plan is to remove to stock sub, pack the space with rock wool, then replace that sub with a higher performing/larger magnet one. I don't think it needs more power as it is already boomy when bass is set to max, it just needs better quality, like a bigger magnet that will allow more accurate cone movement.
I'll post here when I get the guts to pull my brand new car apart. I'll wait for someone else to post a video of how to get to the subwoofer, then take this on.
I just video this exact thing and showed pulling out all the speakers, applying soundproof. waiting for kit and then all the components to install. will video that as well. so at some point I'll be able to upload. it actually was pretty simple ... but getting that stupid seat unplugged was a struggle :-) In hind sight, I should have had someone hold it tilted on its side and then come at from the opposite. But I just wanted to do it more difficult
Awesome, can't wait to see that video! Even just the disassembly for now would be great.
I took apart the rear area today to look at the sub mounting and see if this area could use additional sound insulation/deadener. I've done the sound deadener in the doors and that made a big difference. There is actually a fair amount of insulation in the rear area behind the interior panels but still some opportunity to add a bit more and try to get some deadener applied to the interior of the exterior fiberglass body and around the back of the subwoofer location (I have not removed the sub yet).
below are the steps from the manual to get to the sub area. The clips can be tricky as always, several of mine were partially damaged prior to removing the panels but overall, it was not difficult just a bit hard to access the area.
If one did add an active sub like the one I posted above, where are the RCA sockets to plug it in and where would you wire it in to? Easy job??
This is the concern. To get more low end response, one of those small, self amplified subs would likely be enough. The big enclosures look absolute cack. I had that as a solution in cars 30 years ago and I don’t want to go back to it. Back then head units were easy to replace and easy to add to. I have no idea how you add a sub to the OEM Emira system. Oh for the BOSE system Porsche have been fitting for 25 years…
Connecting into the existing wiring is what is required and thankfully @KJWEmira has done that work. It comes as part of a kit that you can buy from him. Mine arrives in a couple days and I will be installing all new speakers plus a new active sub. Can't wait
I recently added tweeters to the A-Pillars and I'm very satisfied with the outcome. I'd also be willing to add a powered Sub-woofer if, and only if, it could be concealed or hidden as I want to avoid placing anything in the rear shelf which I occasionally do use for storage space. I've checked out some under-seat self powered subs, as they offer this out-of-sight and out-of-the-way benefit for me. I understand that neither the sound quality nor the power of these smaller subs can compare to the larger ones discussed above, but all I'd want to get from an additional sub would be a little more depth in the bass and to have it work in conjunction with (as in an extension of) the OEM Sub by splicing it into the OEM Sub's wires.
Is this workable? Is it even worth it? and if so, are there any recommendations on self powered under seat sub brands? Thanks to all.
