Adding a subwoofer
I fitted the pioneer tweeters today took me 1/2 an hour thanks to the information posted by other members
Absolutely amazing really adds to the sound
I’ve just bought these two items for delivery tomorrow
Does anyone know which side of the car in the rear the wires are to the sub and what the colour codes are
This information will save a whole lot of time
Cheers in advance
Sorry complete novice here…..
So that Kicker RCA thing as per the link above. (£30)
A Kicker Hideaway sub (£300ish)
1) Splice the adapter to the existing sub wires and plug the Hideaway in, mount under or behind the seat.
2) And then have to get power to the battery in the rear compartment.
3) an earth connection will be needed.
That’s it? Sounds fairly straightforward? Not competent at ripping the interior apart.
Could anyone give step by step instructions to the above 3 points? Much appreciated if anyone can!
You’d want someone to confirm an under seat subwoofer actually fits under a seat. I like that idea far more than a sub in a box on the back shelf.
I can help you with 2and3
Tap into the power socket under the arm rest
Kicker Hideaways don’t need the adapter; at least my model didn’t. I had the 10s. It’s built in. Just tap into subwoofer wires and go.
Had two of them in my Vantage
Cheers in advance
It’s on the US passenger side. The wires are directly connected to the sub. I forgot to take pictures when I was in there. But they are pretty easy to spot.
Okay. Took a few pictures. Sorry. Don’t have time to take apart the car right now and I forgot to take them when I initially did it. Also noticed I forgot to heat shrink one of them. Ugh. And need to tie up the power cable a bit more.
Ran power through bulkhead.
Grounded under carpet on shelf to one of the bolts. I did a grounding test to make sure it was viable.
And I tapped into wires prior to subwoofer.
Sorry again for crappy pictures.
Most modern car audio amplifiers and powered subwoofers no longer need a separate line level converter. They usually come equipped with speaker-level inputs as-is. Check to see if the powered subwoofer you are buying has speaker level input already.
It may be possible to remove the stock subwoofer and do a custom fiberglass sealed enclosure there for a 10" subwoofer".
Nova; have you actually checked your own car and subwoofer installation to see if there is actually room to install a (shallow) 10-inch there? You will also need to find out if there is room for the required internal box volume for the sealed woofer cabinet. My favorite driver is the top-of-the-line ETON (German designed & manufactured). I will personally not shy away from the expense, because I come from high-end-audio 🤣🤣🤣😇😇😇
I have 2 cars fitted with Kenwood underseat version, comes with a remote to change bass to your liking. you can't see it at all unless you crouch down, so everything still looks oem
I have not... but it really shouldn't take much space. Stiffly sprung subwoofers made for small sealed enclosures, like the Eaton PW 10 need as little as 10-15 liters of volume for 10" drivers. Essentially you just have to build the box large enough to contain the back of the driver. A custom molded fiberglass enclosure can accomplish this fairly easily, I think, in the available space once the stock subwoofer is removed. Fiber glass enclosures don't have to have thick walls - about 1/4" is usually enough, versus 3/4" for MDF.
For the ones that have already done it...how long to get to the subwoofer? I plan to just replace it with a better one (will make a 3d printed adapter if needed) so I won't be rewiring or adding another one where I need to splice in or anything.
My friend that did mine was here for about 3 hours, but that included an impromptu dj session as well :D
I'd say realistically just to get to the sub to take it out should take around 40 minutes or less, we followed basically those same 4 pdf files to remove panels that are on page 2 from rapture
Hi @FearGuise,
These pictures are helpful, thanks. I'm also about to install a Kicker Hideaway 10", but was wondering if you saved, or can recall, the identifying wire color codes, particularly coming out of the OEM silver Amp that you tapped into. Also, where did you source the power from? In other words, did you get it by also tapping into the same Amp's power wire, or did you source it directly from the car's battery? Thanks again.
The audio system upgrade has taken so much of my time (while I wait), and it looks like there are a few options. I've heard great things about this little guy and am going to see if it work to replace the stock sub (custom enclosure will be needed):
My plan is to do a full DSP/amp and replace every speaker, likely with a K2 of Flax level Focal speaker. I do it all myself so the cost for me is only parts. Spend a couple thousand dollars transforming the audio in a $100k car? No brainer.
just received my focal today and audison amp will be on Friday
That's a neat looking little sub, but it'll be at such a disadvantage in terms of raw physics. Even a low cost 8 inch sub is going to dig deeper and louder... Any reason why you want such a small driver?
Yeah there are a few considerations (there are tons, but these are my most important):
1 - volume of air moved (cone diameter, excursion)
2 - low frequency range
I'm part owner of a headphone company (thinksound) and know a bit about audio, but that doesn't extend to car audio for the most part...some principle are consistent but the environment is completely different. The way I approach the above is:
1 - There's no way around this, the little guy is smaller. It does have a ton of excursion though, so pushes more air than other small subs. An 8" would move more though, no question. I'm not too concerned about this, since the cabin is so small - compare the Emira cabin size to a sedan, and it's pretty clear that the relative air being moved by a little sub is far greater than a big sub in a big car.
2 - This thing hits 35Hz! That's kind of perfect and you'd have to go 10" at least to get lower (in the Focal range for example). Below 30Hz would be great, but I'm more a fan a tight bass vs thumping bass, and I feel that tight controlled sound is more aligned with the spirit of a sports car: precision sound for a precision car. Also, since I'm going to run a DSP, I can extend the frequency range a bit lower than 35Hz.
3 - loudness. Everything will be loud enough, this is a non-issue.
I run an 8" sub under the seats of my old Defender 110 (so 2 total) and they are absolutely perfect: punchy, precise, and you feel it in your chest if the bass is turned up even a little. That experience changed how I plan out audio installs. Full transparency, if I can fit this instead, I probably will: https://www.crutchfield.com/p_091SUBP20S/Focal-P-20-FSE.html?tp=111
I mean, who knows what it will actually sound like...I'll have to install it and report back - car arrives in August...so be patient :)
I’m anyone yet able to confirm whether one of the Pioneer (or similar) underseat subs, actually fits in an Emira?
