- Thread starter
- #281
If you read through the information on Archoil's website (www.archoil.com) you'll see what their product does. Unless there's some kind of import restriction, I don't see why you couldn't buy it there, as well as Redline's oils. I know you can get both on Amazon.Interesting read about your oil additive. Itās not really a thing here in Australia (do we have different quality oils to you, like our fuels?). What does an additive āaddā compared to a good synthetic?
Also, I havenāt gone through all your posts, but did you end up installing the sound deadening material? How did it go, if you did? That added weight would surely counter any reductions from new screws, exhaust, etc.
I haven't done anything with sound deadening yet because we've had a ridiculous spell of heat for the last 5 weeks. It's going to take some time and effort to figure out where and how to dampen noise sources. Now that the 5 week heat spell of 100+ every day has broken, we're starting to see temps in the low 90's in the day, and low 60's at night so the garage is reasonably cool in the morning now. I should be able to spend some time working on this and make some progress.
Next week when I go to change out the muffler with the Aerie titanium one, I'll have the car up on the Quickjack, and I'll start going through with a rubber mallet and doing tap tests all over the underside of the car to see what's making noise and what isn't. I already know the under pan panel in the front is, so I'll remove and dampen that one for sure.
I've downloaded a decibel meter app for my iPhone, so I'm going to see what the sound level is inside the car first. That way I can have some kind of numbers to show what the results are as I go through this. If I find resonant panels, I'll see if I can record those too, so I can do a before/after.
