Attaching the Car key to other keys
Beachbum
What are people using to attach the car key to other keys?
The usual metal ring seems not to fit the Lotus car key, I have tried both large and small rings, with no luck
Wondered if others have had a similar issue and tried other successful options
Interested to hear what they may be.
I use one of these but I don't attach anything to it, it's just to protect the key.
@Bancho Can you still buy them on their own and not in a presentation box?
I'm using a lanyard looped through the key.
But I only have 1 other thing attached to my key.
Anyone aware of an alternative Key, that works with the Emira?
I am working on the assumption, that other keys, that have a useable attachment point, can be programmed to work with the Emira security system, just wondered if anyone knew of any
Can't really help you with that, although I see what you're trying to accomplish there. I'd like to have that alternative also, if indeed there's one available.
The massive size of the Emira FOB has always bothered me, and the silly string thing to attach key rings also seems inappropriate. I would much prefer a slimmer and tasteful design like my 911 FOB, but absent that option, I ultimately went with this (pictured) case was the slimmest that I could find with an integrated quick release key ring. It's sold on AliExpress, it's cheap comes in several colors and has stood up really well so far. Initially, I bought the Ban C leather case, it's really nicely made and all, but because it makes the FOB even more bulky, I put it on my spare FOB and it has been tucked away in a drawer ever since.
Do you have a link to the ones you got? Looking at Amazon, the variations are immense.
I used two 8mm split rings which you can get from Amazon/elsewhere - hope this helps. A bit fiddly to get one attached to the key fob but it is possible.
I've still got a few of these if you are interested:
Take a look at my setup.
I bought a Lotus Leather key ring when I went to England and did the factory tour. It came with a small cord attachment that's perfect for the Emira's key. Here is the direct link to the one I bought (mine is green though)
(https://parts.lotuscars.com/p/Lotus__/Lotus-Leather-Loop-Key-Ring/134540275/LOTMC0083.html)
The attachment is something like this:
(www.amazon.com/SIMMAX-Wrist-Strap-Lanyard-Player/dp/B01MXPUAKT/)
What is that small remote?
I suspected so, but found it odd because patrickramdial appears to be located in Miami (as I am), and isn't the tracker a UK thing only?
Hey! So yeah im from Miami and my tracker is working perfectly fine. The dealership set it up for me the day before I arrived and when we turned the car on to go over everything in the parking lot, I got an email confirming that car was successfully registered.
Where in Miami are you from? I've seen a few around and still have no clue who they belong to!
Cool. I was under the impression that the system only worked in the UK. I'm in Coral Gables, very close to UM.
An update on my key and getting it attached to a key ring. Gave up with the smaller rings, no matter what I did, I ended up bending them to the point, they were no longer a ring and once they were attached, the ends just pocked out and caught on things.
Was given some advice by someone I know who owns a boat, to look at Wire Rope. Comes in various sizes and after a LOT of trial and error, the 1mm stuff works. Various types, but if anyone is interested in doing this you need the following:
https://www.gsproducts.co.uk/7x19-stainless-steel-wire-rope/ - in 1mm. Currently not in stock, so I used
https://www.gsproducts.co.uk/1x19-stainless-steel-wire-rope-rigging/ - 1mm. Its not as flexible as the 7x19, so will likely change it when they get stock
https://www.gsproducts.co.uk/aluminium-steel-wire-rope-loop-ferrules/ - 1mm version
Depending on what you want, you can make the loop as small or big as you want
Hope that helps someone
Thanks for the detailed research. My current cable tie solution looks naff!
Pardon my complete lack of engineering nouse but do you need any special tools to attach and close the crimps?
Allegedly yes, you do need special tools, but I just used Pliers and so far it looks to be ok
I made sure the wire did not come out the other side of the crimps, so no rough edges.
I flattened the crimp initially across the whole crimp, just to hold the wires in place and then did the edges so that they bent over more onto the wire and held it tighter.
Hope that explains it OK. I was pretty easy. The parts are a lot cheaper than I expected, it was the postage that was 3 times the price. If you have a local Chandlers, you might be lucky with them
