Attaching the Car key to other keys
Beachbum
535
362
What are people using to attach the car key to other keys?
The usual metal ring seems not to fit the Lotus car key, I have tried both large and small rings, with no luck
Wondered if others have had a similar issue and tried other successful options
Interested to hear what they may be.
Given I provided the info, thought I'd ask them when they were getting the 1mm 7x19 back in stock. Turns out they arent :(
They however do thinner wire, that "allegedly" will still work with the 1mm Crimps
Unfortunately its still the 7x7 that I listed earlier, but thinner, so more flexible. Given the price, I would suggest ordering at least the 1mm and the 0.81mm and then maybe the 0.72 and then a number of the Crimps, to see which works best.
They also do this stuff:
But no idea how well the plastic sleeving will work with regards to overall thickness
Thanks for going the extra mile on the research! I'll do as you suggested as I'm sure the postage will be the main cost.
on Amazon you can buy a Tesla key fob attachment. it consists of thin cord that attaches to Lotus key and a ring on the other end. I use it and so far so good.
I am trying to keep the volume of it all down, so the key fob case is a last resort for me.
The device Mr.Suntorytime has posted about seems to be ideal, issue for me is getting them to the UK.
Having said that, he also said that to install his attachment, you have to take the fob apart a bit and if that is the case, then other options might be possible
