Bespoke Division to release bilge pump option...
They use resin infusion. All early lotuses were hand laid GRP, which were very variable in weight and shrinkage hence the large panel gaps. If you dont think Lotus have used GRP then you should read some of the books on earlier cars. I discussed how this has come on at the factory earlier this year. Resin infusion has been used for some years which produces a far more uniform consistant panel but at heart its still a GRP composite. If its pure epoxy it wont mind water (even if it shouldn’t be there in the first place) if it isnt its still subject to water damage over a long term. Lotus just need to and indeed probably have fix the bonding issue which is letting water in.In the past Lotus has not used GRP, they used hand-lay fiberglass matting in panel forms with resin literally poured on it and then oven cured. It was a traditional fiberglass layup process with hand finishing.
GRP is a plastics process, and typically uses injection molding or another type of high precision molding. That's not anything that Lotus has done in-house (or on any car before the Emira), to my knowledge.
Third car.Quick question is the Emira one of several cars you’ll own?
You should probably reconsider having this as your only car. Just saying. It's a LOT of compromises.When you consider this would be my only car, the leaks are heartbreaking news
Hand laid fiberglass! You're being excessively pedantic about this topic.They use resin infusion. All early lotuses were hand laid GRP,
It’s a forum for discussion and the materials reaction to water is directly related to the subject raised by the OP and its potential impact on this fault (of which there have been a few reports) and your insistence that Lotuses both current and historic never used GRP could not have been more inaccurate and yes lets drop it.Hand laid fiberglass! You're being excessively pedantic about this topic.
We're talking about panels for the Emira which are injection molded from LIQUID plastic. The only commonality with the process that you are referring to is the fact that they both technically have some glass fiber content in the material.
Can we please drop this side conversation? It's beyond stupid, pedantic, and obnoxious.
ohhh I'd forgotten there was an actual point to this discussion, thanks for bring it back on trackFew comments as OP and who has encountered this problem. First, I drove the car in torrential rain for many km and it has been parked outside during heavy rain for long periods. There are no leaks into cabin or boot.
Secondly, Komotec has not found exact spot where water is entering hatch frame, there is no visible defect.
This issue is not something I would worry too much. Small amount of water will anyway drip into rear boot when you open hatch. Same with Exige and many other cars with similar design. That particular problem will be fixed by manufacturer sooner or later.
no its a separate issue..... water inside an actual panelWhen I tested the car this week the Lotus guy showed me how the rear hatch glass is clear of the bodywork on its lower edge so that engine heat can escape. Thus, when the hatch is lifted, any water present will wash through this opening onto the engine bay, he thought it missed the luggage area.
Is this the leak that is being fussed over? I haven't read the thread in its entirety so please ignore my comments if inappropriate and continue the pissing contest.
If I fall in love after driving the 4 I’ll figure it outYou should probably reconsider having this as your only car. Just saying. It's a LOT of compromises.
I believe they are "chimney" ducts from the engine bay, the rear wheel wells have pressure relief through the rear bumper.With all this talk of water leaking into the engine bay/hatch area (as minor as it may actually be), it got me wondering where these vents drain to... And are they actually letting hot air out from the engine bay or relieving pressure from the inner rear fenders?
for me the ugliest part of the designWith all this talk of water leaking into the engine bay/hatch area (as minor as it may actually be), it got me wondering where these vents drain to... And are they actually letting hot air out from the engine bay or relieving pressure from the inner rear fenders?
I do feel that it might have been better without the mesh. I suspect the aftermarket may provide options in time.for me the ugliest part of the design
yeh, its the only thing I never liked on the car, looking down the side and seeing that bit there.I do feel that it might have been better without the mesh. I suspect the aftermarket may provide options in time.
shall we start meshing around with the grill?I do feel that it might have been better without the mesh. I suspect the aftermarket may provide options in time.
Officially requesting a "pitchforks" reaction emoji...OK folks, get back on topic please. This is about a leak (location not yet identified) causing water to gather inside the hatch panel. It's not about water running off the outside of the hatch into the engine bay, aesthetics of the hatch design etc.
So far this issue has been reported by ONE owner, has been diagnosed, agreed as a manufacturing defect and the part is being replaced as soon as possible by Lotus under warranty. A sense of perspective on this would be useful before sharpening your pitchforks!
