Chronic electrical issues on late 2024 build I4 First edition
I’ve had the same issue as everyone else, left indicator fault and right indicator fault. These happen almost every drive. What I haven’t seen anyone mention is a brake indicator fault but it’s only happened once. It was worse before I charged the battery. The message used to stay until using the turn signal again. Now it will disappear immediately as soon as it appears. I sure hope it will be resolved with a software update don’t really want them tearing apart my car just yet.
We own a 2024 V6 manual, as do close friends whom live nearby. A northern state dwelling relative recently visited our Florida home to compare our Emira driving experience vs. the C8 he was considering buying. After comparing both drives he bought a new I4 First Edition, wanting the auto gearbox so his wife could also drive it, and left it in our garage for now until the weather warms enough to take it home.
When he made the original test drive at the dealer he noticed the yellow triangle/exclamation point displayed but not being familiar with the car thought nothing of it, even though the salesman briefly fussed with the controls to source the problem.
Upon taking delivery the triangle was still there, he had the service department look at it and they declared there was a telematics issue and replaced an antenna and declared it fixed. The owner drive it for an hour before putting it in our garage before going home.
As directed by the owner I started the car several days later and the telematics alarm went off again then shut off, so I drove the car a couple of miles and got a brief fault warning that the left rear blinker had failed. Not long after that another warning about the right blinker failing came up then dissapeared. Over the next three times driving the car the telematics warning came up then disappeared the same with a blinker failure warning. On one of those trips the telematics light stayed on for the whole trip.
I made an appointment at the dealer to fix the problem and dutifully notified the owner.
Enroute to the dealer the taillight warning indicated two times then vanished.
The dealer eventually told us that there had been no codes recorded in the ecu, and they couldn’t figure out the problem and had to contact Lotus ( the taillight warnings popped up irregularly for them as well. Now we’ve been told that there are 40 other cars, all I4s, that have the same problem, and it has not yet been sorted yet- the hope is that it’s a software problem but nothing has fixed it so far. I suspect that the owner of this car might choose to return it and go for the safer bet, the C8. He drove his car once during his ownership, the rest of the time it’s been in the shop with no known resolution. Anyone else had this issue?
Hmmm ... I'm almost certain I briefly saw a turn signal warning at some point during my break-in drive last weekend, but now I can't remember the circumstances and how it cleared. The one annoying thing I've seen is that periodically I get a "WiFi Disconnected" message and my Spotify from the phone (Google Pixel 8 pro Android) will drop out. I guess that is Bluetooth connectivity because it didn't seem to be a problem when the phone was USB-C connected. More things to investigate, but it is parked for the month due to weather and travel.
Thanks for that, I learnt something new. I'd assumed the USB sockets were power-only - but from this post I checked the user manual and read that the USB ports in the armrest supply data as well. Nice to know.
My I4 Emira was delivered mid-January. It arrived state-side on the last boat of 2024. I have about 1300 miles on it now.
I get the right turn signal warning about once per week. It usually disappears within a second, but last time the warning stayed on for a while. Never got a left signal warning.
Two more issues:
One day while shopping the car would not unlock when pushing the button on the key fob. The trunk would not open either. I had to use the physical key to open the door (causing the alarm to go off.) When I got home I switched fobs.
Another day the driver side window would not stay up. After about 10 tries it did. This only happened once.
My turn signal issue has cured itself. 😎 I also had an issue with USB music, that sometimes I need pull the USB drive and reinsert to get it to work. If I didn't know better I'd think there was an over the air update, even though that's not applicable.
My turn signal issue has cured itself. 😎 I also had an issue with USB music, that sometimes in needed pull the USB drive and reinsert to get it to work. If I didn't know better I'd think there was an over the air update, even though that's not applicable.
I've had the USB port problem a couple times on the V6. It just fail to detect the USB drives in the center console, even if I did a reset of the OS but it usually works again on the next trip.
For you guys with the USB issues, is all of your software up to date? Just curious. I have a couple of niggles, as stated, but I also know there are 5 updates that need to be applied. Boggles me that we can't easily get version numbers and release notes for the fixes included said versions.
Yes, had all updates done as of Feb 11th before delivery.
New problem popped up yesterday. My parking brake will not auto disengage anymore, was working fine before then.
Do you know if you have had the DIM update applied? Supposedly, that is specifically for the breaking system(s), per the Lotus Tech I have spoken with.
I have everything that was available done when I picked up at Feb 11th. It's ok as it's going back in for 1K oil change on the 15th. I'll let them take care of it then.
I can't remember exactly which ones, but when I took mine in for the first service (2/28) there were new updates, and I am almost positive the DIM and the IHU updates were brand new.. but don't take that as gospel..
Same here, blinker/turn signal topic happened at least twice. It does appear to go away once you tap either side again. I just grabbed the car on Friday from Los Gatos and drove it back home (LA area). So, I'm about 600 miles into the break-in. Otherwise, enjoying it, but annoyed I can't really "enjoy it" with Sport mode yet.
BTW, pulled over on the way down, got off with a warning and a 10 minute chat about the car and how these are much "bigger" than the "older Lotus" he's use to seeing. He was definitely a lotus fan!
Same here, happened at least twice. It does appear to go away once you tap either side again. I just grabbed the car on Friday from Los Gatos and drove it back home (LA area). So, I'm about 600 miles into the break-in. Otherwise, enjoying it, but annoyed I can't really "enjoy it" with Sport mode yet.
How fast was you going? He probably just want to check out your car. 😁
He said 89, I was thinking that's not fast, that's so cal traffic actually moving!
In all seriousness, he really was cool about it and for anyone interested, I was exceptionally polite and apologetic. I have to believe that came into play when he decided on warning vs. actual ticket. I personally hate seeing idiots chastising LE all over the interwebs/social media. I'm always a bit upset seeing LE put up with that crap (remember, they put their lives up for our sake, even if many don't see it that way). I figure, if I was speeding (even one mile over), I deserved a ticker. If I want to be upset, it should be with myself for having the heavy foot, not LE for doing their job.
85-90 is the average on Hwy 5 between San Jose and LA but I usually try to find a pack of cars and put myself in the middle. Yea, luckily I have not been pulled over for like over 20 years but I was always polite and put my hands where they can see it at all times. It's tough being LE when you never know what kind of people you just pulled over.
I have also had the repeated indicator warning. Collected my car in December 24. Factory order, so shouldn't have been sat around. February 28th after less than 1,000miles, car died completely on me whilst driving. No power to engine, just rolled to a halt. Managed to restart it, and then it did the same again 5 minutes later. Vehicle recovered to Lotus, where it has been since. I spoke with them today and they have diagnosed the fault as water ingress - apparently a common issue on early models but should have been fixed with a design change. However, mine clearly still has the fault. Now requires replacement of two wiring harnesses due to corrosion where water has been sat in/around the wiring. Lotus Customer Care have been horrendous, no updates, resolution or assistance.
Exactly my problem (amongst others) and exactly the same experience of Lotus customer ‘care’
