Do you notice a ticking noise during acceleration?
K_Squared
So I am loving the Emira and at this point I'm just looking into a few small quirks that are somewhat annoying to see if they are normal or exceptions. One such thing is that whenever I accelerate (doesn't matter if it's light or hard acceleration), I notice a subtle ticking noise that I THINK is coming from behind me somewhere. It's difficult to determine the source and I'm going to have to let someone else drive while I try to locate it. The noise doesn't happen when I'm not accelerating so I'm thinking it's either something within the engine or just something in the car that vibrates only during acceleration.
At any rate, I've heard at least 2-3 others report this on Facebook or in this forum so I wanted to put it out there...do you notice this noise and if so, have you been able to identify or address it? It somewhat detracts from the otherwise glorious supercharger and exhaust notes from the engine under normal acceleration.
Thanks in advance!
Has anyone found a definitive solution to this problem? My Emira also started to make the same noise.
I fitted a GRP short shifter on my car and the ticking noise went away. Not a definitive solution but it's accidentally a fix. :unsure:
My dealer couldn't provide me with a solution as the claim they submitted to Lotus was never heard back.
For anyone who has done the shifter boot delete, you can literally stick your hand in and touch/feel/adjust the way the shifter cable is sitting to make the rattling stop.
It's the end links for the cables hitting the bracket they attach at. The cable just "rotates" slightly and they touch. A soft "spacer" of some kind would stop the noise
Status update: I thought the rattling noise was fixed by the short shifter but it's not. The noise is still there but behaves slightly different from before.
