Yes..... We got Auto-Hold?
I hope so! I did tried to switch off engine and restarted at a traffic light ….Software problem!
Park and lock the car, wait 15 minutes, unlock and start the car, and everything will be fine for the next few houres, days, weeks...
Lotus know about the problem.
Cheers
Christian
So we are expected to live with these glitches… forever?Add engine management light to that list...
Came on tonight on way home,unsure how long it had been on.
Parked up to open garage, turned car off , opened garage,turn cat back on,light gone....
The car hadn't been used for a week, I wonder if that contributed, but still wouldn't expect the engine light to come on one of these,new Toyota units...
Not sure if anyone else has experienced the same?
That's Check Engine Light and similar to the "limp mode" or "reduced acceleration" warnings. It's an ECU fault already reported by several people and awaiting a software update by Lotus.Add engine management light to that list...
So advise once a new software update is available ….That's Check Engine Light and similar to the "limp mode" or "reduced acceleration" warnings. It's an ECU fault already reported by several people and awaiting a software update by Lotus.
There are many reports of windows leaking leading to damp interiors and condensation in cold weather.As someone who is going to store the car outside year round (garage not wide enough) this is a bit concerning.
Are wheel covers the answer? With the use of a dryer before covering if wet?
Are there? I've heard of some poorly fitted window seals on the earlier cars but haven't heard of "many reports of windows leaking".There are many reports of windows leaking leading to damp interiors and condensation in cold weather.
I have power washed it and aimed at the seals all around both doors..There are many reports of windows leaking leading to damp interiors and condensation in cold weather.
Might be best to keep it garaged and just use in the summer as apparently the windscreen wipers have been faulty on many cars.
Ah, not used wiper yet. I found in the rain at 105 mph it didn't need a wipe due to the aerodynamics.I had a thought with regards to the wiper issue. Lotus may not have written the software. I believe they took that system from the Geely/Volvo parts bin, so they may be waiting on those guys to troubleshoot the problem and update the software fix for it. If that's the case, that would explain the delay in a fix being issued.
Hi, could you provide a link to the reports of windows leaking. I follow many Lotus forums and social channels and have seen no mention of this.There are many reports of windows leaking leading to damp interiors and condensation in cold weather.
My post few weeks ago about the light stalk not working as per the handbook seems to also be down to a software problem as well so my 'dealer' tells me. Software update due in April.
The '0' tab on the bottom of the light stalk should just be the DRL's on but does not seem to work. i.e. side lights, number plate lights and the green dash tell tale are always on when the engine is running. Also the RESET button on the end of the stalk does not clear Trip A as per the handbook instructions.
Well at least my car doesn't do above properly, I believe all the cars delivered are the same?
if any owners have the just the DRL's working be good to know, to add I think the DRL's are both front and rear lights not sure (but not number plate lights and green tell tale)
If above makes any sense!
Mine will clear trip A if I press and hold the reset button. Does take a few seconds of holding though.My post few weeks ago about the light stalk not working as per the handbook seems to also be down to a software problem as well so my 'dealer' tells me. Software update due in April.
