Emira Standard Wheel Alignment Settings?
Keeping in mind my experience with front steering geometry set up is from superkarts not cars, these settings do make sense considering what each tyre is designed for. Toe out is generally used to give more bite on initial turn in and makes a noticeable difference in the wet. This increased grip when turning in is at the expense of increased rolling resistance/friction when driving in a straight line. Given the Goodyear F1 tyres are more of a road tyre, toe out makes sense. However more grippy tyres (especially with a hot & dry track surface) tend to adopt a toe-out stance naturally so if the geo is already set to toe-out then friction in a straight line is increased even further leading to excessive tyre wear & over heating. Ideally in the dry with sticky tyres, toe would be set to zero. However the tendency to toe out needs to be compensated and by setting the geo to slight toe-in, the tyres naturally run straight. This set up would suit more grippy (sticky) Cup2 tyres on hot dry track days.
The amount of toe change while running depends on compliance and scrub radius. Superkarts have massive scrub radius so they would see more toe out change while running than a car would. I don't know what the scrub radius of the Emira is, but it's probably pretty small and it could even have negative scrub radius. Regardless, they are clearly not speccing the alignment for max track performance. As mentioned previously, my guess is they are just trying to give the cup2s a different steering feel than the goodyears during a test drive type situation since you aren't exactly going to be pushing either to the limit on public roads. At least, I hope people aren't.
Anyone tracked their Emira (Sport with Goodyears) and found any improvements by changing the wheel alignment from stock settings?
Is there any specs for the I4 Emira (Sport) with Cup 2?
My car came with the F1, but I’ve changed to Cup 2 connect (not LTS, got a good deal on these). I’ve also effectively lowered the car by moving the shock circlips (10mm on the shock).
Also, any suggestions for a good track geometry setup? That might improve things and maybe reduce wear on outside edges?
I remember seeing a post in here somewhere that the sport suspension called for marginally more camber than the touring, but it was such a small difference it just seemed like they just wanted to have a difference. For a track setup you'll primarily want more camber, particularly up front. This will help with outside edge wear. Lowering the suspension would have gotten you some more camber, but shouldn't have significantly affected anything else.
Not sure how much adjustment range the Emira has, but a lot of road cars max out their adjustment range before they get to ideal setting. Most track day tires are built for less than ideal camber settings though. Of course if you do a lot of road driving too, you'll then start to wear the inside of the tire more if you put on a lot of camber.
Extra data for everyone here:
Lotus Spec Alignment is more dependent upon tire than suspension.
Front Toe:
Goodyear: -0.10 deg toe out per side
Cup2: +0.01 deg toe in per side
Front Camber:
All Tires: -0.8 deg
Caster:
All Tires: 5 deg
Rear Toe:
All Tires: +0.20 deg toe in per side
Rear Camber:
Goodyear: -1.6 deg
Cup2: -1.8 deg
As for adjustability stock, expect max camber front to be around -1.1 degrees and in the rear -1.9 degrees. I’ve seen these numbers from two of people now.
I asked on the tour and the guide specifically went and found me the answer, which was no.
It appears the ride height difference is just due to slightly different tire sizes (advertised tire sizes are rounded off).
Remember that Lotus is setting these cars up for safe handling and fuel efficiency as street cars. Track alignment will be more aggressive and autocross alignment even more so, likely all the way to the limit for camber.
Thanks guys for the responses. I’ve found and downloaded the sheet where it showed the standard alignments, but only saw V6 (mine’s an I4).
I get it regards the settings now, just try to dial in more camber if possible. Are the I4 alignments listed anywhere? Will speak to Lotus and try to get some info, but getting them to do any work that’s not in the book might be tricky.
I’ve got a feeling the i4 alignment will be close or identical to the v6 alignment because it’s honestly just tire dependent.
Front Toe:
Front Camber:
All Tires: -0.8 deg
Caster:
All Tires: 5 deg
Rear Toe:
Rear Camber:
Goodyear: -1.6 deg
Cup2: -1.8 deg
Hey,
I have knocked my fronts out of alignment, and when going around the garages no one seems to have the spec. Is this a confirmed spec, where did you find it?
thanks in advance
Hey,
thanks in advance
Here's the official alignment specifications:
Thanks. I followed that link you posted a few back, and found some PDFs, the stats are the same, just in a different format. Was just coming back to delete the comment lol. thank you anyway. In the UK, only the dealers seem to have the spec, and they want £600 to do the job !?!
Thanks. I followed that link you posted and found some PDFs, the stats are the same, just in a different format. Was just coming back to delete the comment lol. thank you anyway. In the UK, only the dealers seem to have the spec, and they want £600 to do the job !?!
£600 sounds like a lot for 45 minutes worth of work at most. Most alignment shops here will charge $150-$300 USD for an alignment like this. Dealers are just out there ripping everyone off regardless of country.
They are trying to tell me its a 2.5 hour job
Could take long enough to do. Not sure if the rear under tray has to come off to do the back? You can do the front without removal but there is not much camber adjustment available.
None of the under trays need to be removed.
Just had it done. £75 at a local garage vs the £600 lotus wanted to charge me! There are little tray covers in the rear that they remove to gain access to the adjustments, good design to be fair. So it was all done in an hour.
Side note, none of the car was aligned, to the point where my knock couldn't be the cause. I would advise a check up after you have done the running in, car feels better than day 1 with it tbh.
Good to hear. Just did mine too and car feels much better in terms of steering. Front was off but rear was in pretty good spec.
