I'd rather listen to the engine than Kanye, but we'll have to wait it seems.
This is very interesting. Hopefully it doesn't cost $2,500 like the C8 version does.
This looks pretty simple compared to some of their setups for other cars. These should be a lot less expensive too. Now for some performance numbers and cost!
I don't know if you were joking or not, but in case you weren't, it won't be in the trunk at all. He's holding the unit in his hand, so it's a direct replacement for the factory airbox. If you WERE joking, I actually thought it was funny.Do we think it will still take up the whole trunk?
I don't know...for some reason I think he'll price it at $1,000. The single housing is quite small compared to some of the setups they produce. The dual intake systems they produce for some cars requires two separate molds for left and right, which has to be a big factor in the cost. Those custom molds aren't cheap.I'm betting it'll be ~$1500+ still. Their intakes are beautiful, but damn they're expensive!
Ok my guess is $1900. I hope I am wrong.I don't know...for some reason I think he'll price it at $1,000. The single housing is quite small compared to some of the setups they produce. The dual intake systems they produce for some cars requires two separate molds for left and right, which has to be a big factor in the cost. Those custom molds aren't cheap.
I'm really interested to see if they see the same type of power gains with this intake that they do on some of their more exotic setups.
I've seen the one for the C8 and it takes up half the trunk.I don't know if you were joking or not, but in case you weren't, it won't be in the trunk at all. He's holding the unit in his hand, so it's a direct replacement for the factory airbox. If you WERE joking, I actually thought it was funny.
Do you think the eventuri will fit under the engine cover or will that need to be modified?Yeah but that’s a longitudinally mounted engine which puts the intake at the rear of the car. Ours is transversely mounted so the intake is at the left of the car.
And it'll weigh less I bet!
For sure it will weigh less but I’m hoping nothing has to be modified to get it in. I’m also interested to see if it makes air flow in the already limited space around the engine more restricted.And it'll weigh less I bet!
Is it 1 air filter or one for each bank?You can see from the picture how sleek this unit is, especially compared to the factory intake. The part on the bottom replaces the factory side intake, and the part at the top connects to the engine. Pretty clean overall. Hopefully it's fairly easy to take apart when it comes time to clean the filter.
One.Is it 1 air filter or one for each bank?
