Yes, good idea. It is also worth cleaning the edge of the wiper blades too, just to make sure there isn't anything on them.Will give this try. I’m going to clay the windscreen to remove any contaminants, then rain X.
It's funny how cars vary so much, but there is nothing more irritating than wipers skipping/dragging across a windscreen.The wipers in my Emira glide over the windscreen very smoothly. Actually the best amongst all cars I owned so far!
Can someone hold a hose and shower the front of the car while you record the video?I took a quick video in the dry (so unfortunately not able to show the problematic behavior once the interval mode had been activated before).
Sad they still don't know what's up. NOTHING works besides immediately putting it into high after starting. I used the flick down only in light rain, hoping high would work if rain comes pouring. Nope. Low mode and high later? Starting in high, go to low or off, high later? Nope. I'm 7k km in, good part on the Autobahn. It's stupid.He explained the problem could be managed by not putting the wipers into Auto. Leave them off, use the flick down or put them manually straight into low speed.
That is a very sensible idea. I am going to email them to that effect ! They really need to sort something.If they can, they need to come up with a temporary software disable of the sensor system. Just go to direct control by the steering wheel stalk so people can use the wipers properly until they come up with the fix for the sensor system.
Wait you think that’s a step up? In what because it won’t be reliability.On another note, if you get into an accident due to this, I would sue lotus for it, then stepping up to Ferrari/Mclaren brand.
Well, that 'clears' that up.Ok. So it rained today and I have been out wiper testing. Straight out the garage mine does what the one in the video does. Normal and fast work fine. If I go for a drive with it in intermittent for a while and then switch it up to normal all is ok, but if I then switch it to fast it stays in normal. If I stop and cycle the ignition, I get fast speed back again. So my earlier comment that mine were working fine turns out not to be as correct as I thought.
