AlSalas131
Just drove the car home last night and when stopping the whole electric system shutdown, dark, nothing working. Has anyone heard of this issue? Nothing has power.
Checked the battery and is fine. The car was driving fine and when I stopped everything went dark, full electrical failure just like if the battery was not even connected. No idea how is that even possible. Just like unplugging a cord from the outlet. No warning or issues whatsoever prior to shutting off.Either a total battery failure, or one of the battery terminal connectors came loose.
Fuses? Battery fuse box is right on the front of the battery.Checked the battery and is fine. The car was driving fine and when I stopped everything went dark, full electrical failure just like if the battery was not even connected. No idea how is that even possible. Just like unplugging a cord from the outlet. No warning or issues whatsoever prior to shutting off.
Checked the mega fuse box and looks OK. I actually have my CTek connectors to the + jump plate and the negative battery pole. Did that a week ago and the car has been working fine. Had you done any similar work back there?
Mine was the alternator but everything including the car died while driving (posted in another thread)Just drove the car home last night and when stopping the whole electric system shutdown, dark, nothing working. Has anyone heard of this issue? Nothing has power.
My car shut off with everything else. Is a manual but did not try to start it by pushing it since I have no electronics anyway and Lotus is picking it up on Monday.Mine was the alternator but everything including the car died while driving (posted in another thread)
Sounds like you could drive
Lotus Emira battery dies while driving or can it be the alternator?
Hit 1,000 miles yesterday and right after I stopped at a store and restarted the car I get this message (pic below). Drove home, put on battery tender for 6 hours and went out at night. Battery error gone. Valet comes in to find me at restaurant and said my car doesn’t start (initially thought...www.emiraforum.com
Then the same problem as mineMy car shut off with everything else. Is a manual but did not try to start it by pushing it since I have no electronics anyway and Lotus is picking it up on Monday.
I had a similar issue, full shut down, need to use the manual boot release to get to the battery, after the 3rd occsasion over a few days finally check the terminal for tightness, the positive was loose. Not had any issue since.Then the same problem as mine
Alternator I bet
Now about half a dozen or more with same issue it seems
