KEF Audio Upgrade Parts - Now Available!
Hi- do you install this kit professionally or did you just fit to your own car?
Hi John,
I just installed to my own car and engineered the speaker & amp mounts, although I've worked on cars most of my career.
I can highly recommend an installer in the South-East (Maidstone area) if you're local?
Speaker Wiring - The speaker outputs from the original 2 Amps are used - these original amps remain in place. Once an order is placed, I'll send you a document which contains a list of all the speaker wires & colour codes allowing quick and easy identification. The original 2 amps and Audsion amp will all situated in the same area, all that is required is to find the outputs from the original amps (using the colour code document), cut into these and connect to the input of the Audison amp.
As the speakers I've used are much larger / powerful, I suggest running new speaker wire to all speakers. When the rear of the vehicle is stripped down this will be straight forward, there is plenty of spspace.
Nice setup and parts you've made!
Is there a reason way you kept the original amps?
If there is signal lines from the head unit I assume it would be a better end result to use this and skip the original amps?
I haven't received my Emira yet, so only in planning phase of audio upgrade and seeking information to see different options.
Hi @Sjobing,
Good question - Unfortunately with modern cars it is just not as simple as removing a module / control unit / amp as this will log faults - all modules communicate with each other in one way or another.
Also, it is not 100% what else these amp modules serve, for example, all the warnings chimes are heard through the cars speakers together with parking sensors, mobile phone connectivity, sat-nav, radio, etc etc. and finally for the equalizer to continue to work.
My advise would be to leave the OEM products in the car and install an additional amplifier. This is where Audison has the market for integration.
Should an audio upgrade be something you are considering then its worth taking a look at the Audison Youtube page as they explain everything regarding this subject. They're expensive products but works perfectly and 100% programmable.
Hi @Sjobing,
Hi @KJWEmira
Thank' for a good reply.
I see your point, but I might investigate further to see what happens if original amps ar3 disconnected/removed. I intend to keep the Emira forever, so I might use some more time to build a decent sound system in it compared to my MB I use for dd/work.
My plan is to use DSP/amp from the HELIX range from Audiotec Fischer, and speakers from the Focal K2 Power M range.
Plan is tweeter on dash/a pillar, 6.5 KM in doors and 2 x Sub 5 KM in the rear. I'll make a custom cabinet for the sub's and have some ideas, but I need to get the car so I can have a closer look if my ideas is doable in the space available.
I know of Audison but I'm familiar with the DSP software from Audiotec Fischer, as I have DSP/amps from them in my MB E400d AT where I did an upgrade of the Burmester system to get it more to my taste. I've also used Focal speakers in this car and some of my former cars.
So that's the reason I stick with these brands.
Hi @KJWEmira
@Sjobing - This sounds very interesting and we'd all be keen to know how your install turns out. If I can be of any assistance then please feel free to reach out (y).
Also, thank you for the links, I'll take a look at both when time permits.
Just out of curiosity, did you remove the OEM amps from your MB prior to installing the Audiotec Amp(s)?
@KJWEmira
I will update, but I will probably don't start any build before next winter. I will enjoy driving and finish my new garage this summer, so I have a decent working space for projects like this during winter and snow. :)
No I didn't remove the amps in my MB. Here I got a complete plug'n play harness to put the new DSP/amp into the original wiring in the car.
I also wanted to keep it fairly simple to remove all equipment I put in this car since I drive this ca 60.000 km/year and change this more often than I intend to do with the Emira.
with your speaker adapters, how deep of a speaker can you mount?
Hi docron,
The Hertz Mille ML 1650.3 speakers I used are 3.15 in. (80mm) depth, which easily cleared the window - see below snip direct from Hertz Audio website.
What speakers are you wanting to install?
probably some Focals, just needed to figure out if needed slim or regular speaker depth. thanks for information!
@KJWEmira do you know where we can get full wiring schematic for the I4 audio system, specifically what's going into the DSP unit? Lotus service said UK told them the fake engine noise is being put out directly by the DSP, so something must be feeding it rpm signal. Just continuing on our quest to solve this audio issue...so I can turn my amp back on lol
@Kaz - I've reached out to a few people to request some further information on this subject. I'll revert back once I get a response.
What I've requested is from where this sound is generated and is it possible to interrupt a signal / wire to stop it, or is it a coding / programming resolution only.
