Please let us know if camber increase is possible without spending $10,000I always thought the emira camber range was really small. Makes sense that you need less camber with double wishbone. In past cars I was always trying to set max negative camber without excessive tire wear.
If standard sports springs are 60/115, what is the spec for touring? ThanksStandard front camber is around -0.8. It’s double wishbone so not too much needed. Camber won’t help with turn in, but can improve corner grip. Too much negative and you’ll get decreased breaking grip. When on track measure temps across tyre to get the best setup for the circuit. You can get sharper turn in with more front toe out. You’ll want to harden up your spring and damper combo too. I recommend going at least 80/130 Nm/mm front/rear for track. This will start to get on the harsh side for road but not overly. Standard sports springs are 60/115
The point I was making was that you may not need as much negative camber as @Honcho pointed out because the double wishbones. If you want more, yeah can be expensive.Please let us know if camber increase is possible without spending $10,000
I can get you upgraded front and rear control arms for way less from my tuner, PM me if interested.
55/110If standard sports springs are 60/115, what is the spec for touring? Thanks
