Lowering question for GRP (and any others)
  • Thread starter Thread starter Guest2937
  • Start date Start date
G
Guest2937
Guest
@GRP for customers who have ordered your lowering kit, do you have any sense how much people are lowering their Emiras? 15mm? 20? And what proportion are adding wheel spacers?
I like the stance on the Eventuri Emira, which they told me was lowered (but didn't tell me how much), and they said they didn't use spacers:
I also like the stance on this one that I found on Reddit:
Any thoughts you have would be appreciated! I want to close the gap and make the stance more aggressive, but don't want to run into issues with scraping, etc..
Thanks,
BLD_Emira
You can do Greg’s lowering sleeves and 12mm spacers to get the look you want. I think 15-20mm is the max on the lowering sleeves. Any lower and the lock nut rubs against the axle boot in the rear. If you want to go lower you’ll have to go with a full coilover as those have more clearance to the axle boot.
Thanks,
BLD_Emira
The Eventuri Emira has rather sunken looking wheels when you see it on video(IMO). The Emira is fine at standard height with stock offset, but definitely looks better with some spacers, once lowered.
I’ve had the GRP lowering kit added and the lotus dealer maxed it to its lowest point. They also put on the 12 mm spacers.
I’ve had no problems with any scraping or wheel arch issues. The only problem I have now is tripping over on footpath faults when I park the car because I can’t get my eyes off it. It looks sensational!
Thanks,
BLD_Emira
The second photo is a render or photo from
Video game etc
Mine was lowered with the lowering kit at its lowest point I think , and only touch to the ground only going downhill to some parking
Also put the 12mm spacers
Love the look
Does lowering the car make the ride a little more harsh/stiffer?
GRP It feels pretty much the same as stock sports suspension. I have to concentrate hard to find differences in stiffness. Its def more planted on straights and less nose lift in quick accelerations.
If you get coilovers, you can adjust a knob to feel any way you want no matter how low. Only downside is that it's expensive for Emiras.
Do we know how low we can set the oem springs? Also, I tend to stay away from front spacers as any slight vibration at the wheel and I'll lose my mind. Any vibes from grp?
You can do 15-20mm max in the rear before the locknut hits the rear axle boots. I’d stay around 15mm to be safe myself. Front spacers that are hub centric are fine so long as you provide a nice clean mating surface for both the hub and the wheel, but that is true for any interface that rotates.
Reactions: GRP
I don't think I phrased my question well enough. I'm curious if the oem system can be lowered without going to the aftermarket? I believe I read there's up to 10mm of adjustment there.
Ah you're talking about the three circlip positions on the damper body that the spring seat sits on.
Unfortunately at least on the v6 manual sport setup I have, the circlip in the rear is already on the the lowest setting and the front is on the middle setting. You can basically lower the front by 5mm and that's it, which doesn't make sense since the rear has a larger visual gap.
I can't speak for touring suspension setup nor automatic or i4s, those could have an entirely different configuration.
Can you see this setup with the car on the ground in the touring setup? I have the touring but not sure where to look and if I can even see what setting it's on while it's on the ground.. Is this possible to tell without lifting up the car?
Sorry you won't be able to see it without removing the damper from the vehicle and removing the spring from the damper.
The silver spring seat sits on a circlip on the damper body:
Similar to this, but our spring perch sits inverted and hides which slot it sits on.
You sir.. are a wealth of knowledge and are insanely generous with it... I appreciate it..
GRP lowering here we come (I Think)
I am debating lowering it myself just because of scraping and the roads here in Florida.. The LOOK is amazing.. but functionally not sure.
We have high slope underground garage here in China, and I was a bit worried before I lowered, but turns out the front splitters of the Emira has very good clearance and I haven't scape once (touch wood)
Hi Folks,
Quite a number of members have posted here having installed the GRP Lowering Sleeves. I decided to order them as well and received them fairly quick. I subsequently spoke to Greg who gave me a few helpful pointers on the coil-over removals and sleeve adjustments, but I'm still undecided as to how many millimeters to drop. I'm inclined to initially go 15mm and see how the arch gap looks.
I understand that the wheel arch/tire gap is a controversial theme with some finding the OEM gaps perfectly fine, but I, along with many others, do find that wide gap to take away from the car's sportiness. I particularly dislike the excessive gap, IMO, in the rear wheel arches where they are even more pronounced. Since I first observed it, my eyes keep constantly being drawn to that rear arch gap. This brings me to my point... in preparation for the sleeves' installment, I began taking some true measurements, the results of which are shown below...
Front Arch
Rear Arch
I was intrigued with the difference front-to-rear, so I took a level to the bottom lateral rail by the mid-section under tray. This rail has a perfect unobstructed groove where to place a level. What I discovered was this...
Not level, with a high bias to rear.
Proof that it wasn't the garage floor's fault.
This is to visualize the difference in level. The leveling gap approx. 5mm
My V6 manual Emira is on Touring suspension and has OEM wheels with 12mm spacers on all 4 wheels.
These measurements brought me to the conclusion that the rear wheel arch/tire gap is indeed much greater (9mm) and not a mere visual illusion, and that, in general, the front of the car is lower than the rear.
A couple of questions for Emira owners here, if you can check:
1) Do you have the same difference in front-to rear arch gaps and, if so, do you know it to be normal?
2) Is your car leveled and, if not, do you know it to be normal?
My other cars are level from-to-rear, so depending on your feedback, I'm tempted to set the rear sleeves lower than the front, in order to compensate the rear height bias.
Your thoughts?
Hi Folks,
Front Arch
Rear Arch
This is to visualize the difference in level. The leveling gap approx. 5mmView attachment 55834
My other cars are level from-to-rear, so depending on your feedback, I'm tempted to set the rear sleeves lower than the front, in order to compensate the rear hight bias.
Your thoughts?
Completely normal, the Emira has a forward rake.
If you want an even ride height indeed you will need to lower the rears more than the front, but you are limited to 15-20mm of lowering in the rear.
