Kentviking
Don't know if its been posted elsewhere, but just saw this vid...and apparently the rear shelf behind the seats can only take 20Kg . btw...the dark verdant and tan look awesome here.
as I only use carry on, it can easilly get to 15 kilos, yes above the 10 kilo limit, but they generally dont weigh it.When you travel, how much does your overhead case weigh (yours, not your girls)
and what if I want some sexy time back there with the Mrs? haha...shes slim but not that slimIt must be from a H&S perspective surely with objects flying fwds under heavy breaking?
Cant be a structural thing surely 🤔
you would have to assume... to have an effective chasm of such low support just behind the seats would be a bit of a worry...! Sorry if missed anywhere else, but if there is such a tight limit on luggage weight there, was there one set for the seats/passengers...?It must be from a H&S perspective surely with objects flying fwds under heavy braking?
probably a thin light grade aluminium .... saving potentially 3/4 of a kilo at best.... it all helps, but this is plain stupidin the opinion of the person doing the video he says the floor isn't of substance and it bends.
ive no idea....id think with the solid engine right behind there and solid floor right in front.... cant see how that area needs to flex, but I could be wrong. Seeing how lotus have been so far, I would not give them much benefit of the doubtIt may not be just for weight savings though, it may be for chassis flex dynamics right?
I assume that's what it means as well, but it doesn't SAY that. It says 20kg limit. Which is shocking for a storage area designed to carry luggage.20kgs per side, probably relates to retaining net.
Rear cabin space | Lotus Emira Talk | 6 | ||
J | Rear lights ON when trunk open ? | Lotus Emira Electronics | 5 | |
Rattle from rear glass area? | Lotus Emira Interior | 1 |
