Rear view mirror - vibrating
217
141
On my 150 mile drive back home from dealer, I really noticed the vibrating of the rear view mirror when the engine was lugging (running under 2k RPMs ) mostly around 1500 rpm in 8th gear . I'm already thinking about shoving in a piece of urethane to provide additional pressure to help stabilize.
Anyone else notice this?
I4 delivered today to my house, 10F outside this morning I wasn't driving it home. Summer tires. I
Help- Drivers side window a small window decal says: Can someone explain this.
Let me know if you find a solve, I have a similar issue
The resolution should be the dealer fixing this, apologising profusely for not picking it up during the PDI and offering at least some recompense.
I asked my dealer to look into mine. They said it was within tolerance and sent me on my way. Definitely one of the issues that irks me the most as it makes seeing behind me difficult on the freeway.
Exactly, mirror is stable when engine in humming along and feels secure when you move it. It's just at low rpms the engine generates a vibration the shakes the mirror, needs another stabilization point. Sendmeows - are you a v6 or 4?
V6.
You can place a shim/spacer between the mirror and plastic trim cover just behind the mirror. Wedge your finger from under the mirror to simulate what it does. I'll grab a photo if that's not clear.
This is a sticker for the dealer, part of the PDI. Was on my car before I picked it up and the dealer pointed it out and explained. When you open you door do the windows drop a bit? If so, the dealer did it, but didn't remove the sticker.. If not, I would mention it, or review the manual and set the window drop.
