KAR120C
Drive the Schweinefiletring!
I’m a little confused over your example. Upshift tire chirping is only the result of clutch release speed and amount of throttle. That is, unmatched revs with a lot of power means the tires are forced to spin to adjust. Speed of the shift is irrelevant.I'll grant that standard teaching is going to tell you to remove your foot from throttle to do any clutch-in operation, and it should drop the RPM once you have begun clutch in. But, overall, if you are really shifting fast, this isn't that much different from downshifting without throttle blip. If you are shifting fast, acting as if you a doing something like drag racing, I would point to the fact that tire-chirp on gear shift indicates there is the shock to the drive line.
I don't know about you, but I don't flat-foot downshift, Most time when I'm realizing I need to downshift, I'm just cruising at highway speed, I definitely don't go full throttle before downshifting. So, yeah you definitely are not going to be matching engine speed and trans shaft speed at that point. I know a number of other cars do auto-rev matching for situations like this though.
The point of downshift rev matching is not to go full throttle on downshift. Just enough make it smooth. If you are just downshifting to accelerate just keep enough throttle so revs climb while you complete the shift. Then hard throttle.
I assure you that with practice it is not difficult to rev match in every situation shifting up or down. It’ll become SOP and you won’t even need to think about it. Tire chirp just says you haven’t mastered it yet or are willing to put your drivetrain through a hard shock.
