@GRP are there EBC pads that don't require disassembly to fit the Emira?
All of the pads to suit the Emira are drop in -- no major disassembly required really.
Pop the pins out, pull out the old pads, compress the pistons and drop in the new pads.
The only issue is that the pads are a little thicker so I had to remove the rubber backing plate from the pads to make them fit
One of you is a liar, and now you must fight to the death! :)
I think Greg meant no major disassembly of the car is required to swap the pads. But for the EBC pads to fit you do have to remove the backing.
Reactions: GRP
Lol Exactly what @silent cilantro said.
You dont need to remove the calipers to swap the pads is what I meant
Just get the black calipers and you can spend more time driving and less time cleaning.
It's not just the calipers that get dirty/filthy.. It's the entire silver wheel plus the calipers. It's crazy after a single drive how much dust there is on the wheels and calipers.
Ryan G
I'm not familiar with doing this previously but I definitely don't want squeak. I'd rather clean my wheels often over it.
Same here.. Wondering if anyone will make a true Emira low dust brake pad soon. I am all in for some of that to not have to clean my wheels after every drive.
Ryan G
Finally set up Homelink, after much troubleshooting. Turns out it's very important to have a fresh battery in the garage door opener.
I've never been able to figure out Homelink on any of my cars.
I got Tailwind. It knows which doors to open and close automatically via each cars Bluetooth. Pretty slick 👍
Black wheels! :)
So true. I love the silver on my Nimbus, but don't wash it very much. Between the bugs and dust, it gets rough after a few drives. I wish I'd gone black to just to cover my sins. I just touched it with a wet rag to see how bad it was.
Pretty bad.
Pretty bad.
My black rims keep their appearance even with the dust, which softens their sheen. You know it's there but likely less obstrusvely.
What is the name of the UK company that supplies the Alcantara shift boots? I know it has been mentioned on the forum. I have tried several search terms, but I cannot find it.
It's worse with the louvered hatch on my Evora. Water gets in there no matter what.
Chose to be cautious and arranged for 1,000 mile dealer oil and filter change.
About 275 dollars plus tax.
Found out I was due for 2 software updates: one relates to the occasional popping sound coming from the KEF system.
Also, there is a dealer fix from Lotus regarding installing a shroud (my term) to protect the AC wiring assembly from water entering the hood vent. Anyone asking/getting - install takes 2 hours.
And.... received my Lotus Shop Manual copy.
The car is settling in nicely and I swear it drives better each time.
$275 doesn't seem bad, my local dealer is quoting around $500-600.:confused:
My local Exotic shop wanted $400 for the oil change and another $400 while doing the oil change to do the Valve controller and 3rd cat delete.. I thought that was excessive.
I got another shop to quote the oil change at $150 (they do exotics as well) and then another $300 for the 3rd cat delete and valve controller.. So I am going there.
Ryan G
Hey all, looking for some advice. I have my Emira at Galpin Auto Sports getting some parts fitted. Seems like they're having issues with the decat pipe (ugh) and the wheel spacers. Any thoughts? I've never heard anyone having issues from the wheel spacers.
