Wireless phone charger option
JT Ramona CA
New member
I wanted a wireless charger in the Emira, did not really like any of the Chargers, that clipped to the vents or put the phone in the way in the relatively small Emira cockpit. My iPhone 14 is a little thick with the protective case on it, so I decided against the option of putting it in the little slot in front of the gearshift. On the Emira V6 Automatic the area underneath the center console has plenty of space for the phone. I purchased a wireless charger from Amazon https://www.amazon.com/dp/B0D3LCHL91?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1, and using double sided tape and Velcro, mounted the round wireless charger on top of a hockey puck that is also stuck to the rubber mat at the bottom of the storage area with double sticky tape. The connection for the charger is right there in the storage compartment, out of the way, easy to hook up to. The solution has worked out really nice, and can be easily removed with no damage or drilling to the car.
Easy/practical solution for i4 owners and a great helpful way to introduce yourself to the Forum. Welcome!
I think I know which iPhone mount you used ...
I would suggest an alternative for the mounting position ... works very well also with enough passenger knee room ...
Originally I looked for a similar position next to the central display, but didn't find any sticker that would perfectly fit the limited "attachment" area and disliked the "overlooking" bit
Best regards
Christian
