Yes, correct.You still have the third cat installed, correct?
I'm 195lbs and stand/crouch In the trunk on my 400 and Emira no problem. Only way to access the Slave cylinder to bleed clutch to my knowledge on the 400/GT.Unfortunately you can't stand or sit in the trunk. It's just like you said. Stand on tip toes while leaning over the trunk trying to reach everything. That gets real old in a hurry.
Lotus says in the manual to not put more than 50 kg (110 lbs) of weight in the trunk? Is that limit just for driving purposes?I'm 195lbs and stand/crouch In the trunk on my 400 and Emira no problem. Only way to access the Slave cylinder to bleed clutch to my knowledge on the 400/GT.
