Unfortunately you can't stand or sit in the trunk. It's just like you said. Stand on tip toes while leaning over the trunk trying to reach everything. That gets real old in a hurry.
I'm 195lbs and stand/crouch In the trunk on my 400 and Emira no problem. Only way to access the Slave cylinder to bleed clutch to my knowledge on the 400/GT.
  • #344
Lotus says in the manual to not put more than 50 kg (110 lbs) of weight in the trunk? Is that limit just for driving purposes?
Yeah there's a weight limit sticker in the trunk too but I've never had an issue on the 400 just getting in and working over the engine. I did the same for the intake on the Emira and no wierd noises. I would suggest smooth movements but so far so good lol
Edit: and that page in the manual suggests it's for handling purposes not load bearing of the trunk itself. Neat! never knew that.
The only way you’re installing this without being 7 feet tall is either a lay over creeper or sitting in the trunk/engine area.
Eagle7, I'm curious. After having changed the transmission fluid a while back, do you find that the gear shifts are easier/smoother or can be done more quickly than when the stock fluid was used? I realize you also added the other additive but wanted to check in on this.
