luciddaydream
Hi there
Thanks a ton
I had my place ceramic coat the wheels and calipers with 2 coats.. It's easier to clean for sure but it doesn't stop the dust from collecting.. It does only take about 10 mins to wipe off the wheels though with the ceramic and a proper brush..
I too am waiting on a proper pad to reduce the dust considerably. Sadly I am NOT mechanically inclined so I can't do it myself and I don't really trust a shop to do it like @kitkat did and not cut corners..
I guess I will wait until someone comes out with a perfect fit pad.
Ryan G
I’m installing Racing Brake’s new pads in 2 weeks, will let you know how it works out.
The most direct way is to replace the brake pads with more metal components, but ,can the original brake pads withstand is a problem, and this brake pad will have a sharp sound when the heavy brake, my other car replaced the high-carbon steel brake disc and track brake skin, brake performance improved a lot, dust is less, but more noise
