You walk past a big mirror and say....What are you looking at!?...And you're like...Ohhh, it's just meAgreed. To each their own. I didn’t expect such a strong reaction to my comment.
Ha! Or I’m just trying to keep the forum positive. If I inadvertently offend a snowflake I’ll try to walk it back. Pretty sure I’m being trolled now though so I’m done.You walk past a big mirror and say....What are you looking at!?...And you're like...Ohhh, it's just me
You can do all the weight saving out there but at the end of the day if you want the Emira to deliver what you think it should being as exotic looking car, you will need to add more power IMO! I think the sweet spot is JUBU 460 Kit with all weight saving you can do. If you have the money I think the JUBU 500 is absolutely perfect!
I loved the Emira in many aspect but 1 main concern when I test drove it. It’s not a fast car. People that tell you it’s fast, haven’t had fast cars. It’s quick yes and it’s plenty for most, which is why Lotus gave it what it did. They are not wrong since people are buying them and loving it. But the cost your paying isn’t for the power and I think we can all agree on this, do we wish we all were given more yes obviously lol!
That being said when I placed my order I knew I would be upgrading the power and I have already gone with the JUBU 440 kit. Absolutely love it has a launch control and raising the rpm to 7,200 was also a need since I felt it cut power sooner than the claimed 6,800 (others have said the same thing so it’s not wrong, some just are more in tune with what’s going on than others) The way I have my car set up now is how the car “power wise” should have come from the factory. So to me I am where I should have been stock, so I do plan on further stages soon probably the end all be all for me is the JUBU 500 with forged internals down the road.
I know these stages will cost money but at the end of the day I will pay just over what a manual GT4 would cost me (new as I would spec before I lost my allocation since they discontinued it)
and I will have more power, better handling (with some more mods) way better looking/special looking car and better sounding.
It cost less to go with JUBU 460 then do all the weight savings. So how I structured my build is 440 JUBU with some weight saving small items exhaust and battery, next is 460 JUBU then all other impactful weight saving mods like wheels and seats etc.
I think with this I will be really happy for awhile bc I would have saved around 130-150 lbs give or take depending what I choose, and ill be at minimum 460 hp as the tune only restricts tq so depending on my specific engine I could be at 475-490 according to JUBU. I would do a dyno at some point to see my numbers and my tq is limited at max 369 lb/ft until I do the 500 kit.
That’s my plan doesn’t have to be yours, make it your own, be honest in what you want out of your car realistically with your budget and needs, make a plan to get there dont stress and enjoy driving the car in the process and don’t wait till the “build” is done bc we all know it’s never done lol. Stay in present, enjoy the journey and have fun!![]()
Only raise to 7k there is a system issue do show about that, but you can still go to 7200. Shifting at 7k on the dash thou is still really nice!Does the JUBU raise the redline on the dash display too?
Only 163 mph
There's really no need to get all up in arms over this. It's a car, and like pretty much any car that's stock from the factory, it's a base starting point for performance increases which is typically what modding is all about.
A Lotus has never been about power or straight line acceleration, but this one is reasonably close to be worth (in my opinion) spending a few coins to improve it, which is what I'm doing. I also enjoy doing this.
There's also two types of weight reduction; static weight and rotating weight. The Honda report was only talking about static weight reduction. Reducing rotating weight, especially unsprung rotating weight is by far much more beneficial. The 2 areas where that's doable are wheels and brake rotors. Engine flywheel and/or clutch (if it's a manual trans.) is another area where the benefit is greater than the amount of weight removed. Better oils that reduce friction and lower resistance can also help.
On the scale of benefit to cost, the cheapest way to start reducing weight is to replace the 43 lb factory battery with a 13 lb Antigravity 40ah battery (GRP sells these) which currently is $819. That's an instant 30 lb reduction with no modifications necessary; slides right into the factory mounts.
The prices start to go up from there for mod improvements.
The next best value (from my experience) was the Eventuri, which cost $1,600 but delivered a clean increase of 16 hp and 15 ft lbs of torque to the rear wheels. I know GRP's same-day test of the Eventuri and other intakes didn't produce those kinds of numbers, but I suspect it was because the ECU didn't have enough time to adjust to each of them. I've done multiple dyno runs stretched out over months, and the results are always consistent.
Next I would put lighter wheels as a good mod. @Aerie has some nice offerings that will typically remove a combined weight of about 24 lbs for all 4 wheels. That's unsprung rotating weight (URW). There are several different opinions of how much of a weight reduction benefit that gives, from anywhere to the equivalent of 4x to 10x the amount of static weight. Just to be conservative, even if you go with the lowest of 4x, removing 24 lbs of URW would have the equivalent effect of removing 96 lbs of static weight. That you can feel. A set of forged aluminum wheels from Aerie will be around $3k (providing tariffs don't change that) which includes shipping. They're well-made, with good finishes.
I know a lot of people do 3rd cat deletes, but I didn't do that so I don't have any data to share. According to Jubu, that supposedly frees up about 5 hp to the rear wheels so that may be worthwhile, and it's relatively cheap if you don't mind the extra noise. Many want the noise, but I didn't.
The titanium exhaust is nice, but at $2,500 it's a bit pricey and isn't going to give you the same benefit spending that same amount of money would on a lighter set of wheels. Depends on your budget and what you want to spend. The benefit of the titanium exhaust is a reduction in weight of about 18 lbs (for the Aerie), and when I dynoed it, there was an increase in torque up to about 2800 rpm, which was nice. I feel more torque at the lower rpms is what the Emira needs the most.
Now you start getting into the really expensive mods. Seats are going to be above $6k, but you do get about a 66 lb reduction in weight. According to @kitkat it does get much louder inside the car; the factory seats apparently absorb a lot of noise. This mod is debatable for a street build, but probably worthwhile for a track focused build.
Next would be either expensive wheels even lighter than what Aerie provides, but now you're up around $10k. What I've chosen to do is go with @Warren-RB RacingBrake's carbon ceramic rotor kit. Also not cheap at $11,600, but it's a reduction of about 23 lbs of URW which according to the 4x formula, will have the effect of removing 92 lbs of static weight. In addition, there should be a drastic reduction in brake dust issues. So between the lighter Aerie wheels and the RB CCB rotors, that's an equivalent weight reduction of 188 lbs, not to mention the actual static weight reduction.
So do you 'have' to do any of this? No, of course not. The Emira as-is is a really nice sports car. If you want a bit more performance, I would say based on my experience, the Eventuri will do the most for you, even before the lighter battery. After that, it's up to you, your budget, and how much you want to do and spend.
This is very useful. I'd be a shame to get this information lost in the middle of this post... Ideally it should have its own post and perhaps made as a table that people can keep adding with new modifications / weight saved / hp gainsThere's really no need to get all up in arms over this. It's a car, and like pretty much any car that's stock from the factory, it's a base starting point for performance increases which is typically what modding is all about.
The problem with this test is the wheel sizes and tire widths keep changing, which isn't really representative of reducing URW for the same size wheels and tires. By the time they get down to the 15" wheels, it's on the same car with the same body mass weight, but they've lost 2.5" of tire width, the lateral g's have gone down, and the braking distance has increased by 4 feet. If they had done a test with the original 19x8.5" size wheels where they had switched to a set the same size but 14 lbs lighter, that would be a much more realistic representation of the actual effect.I just don't think the rotational mass myth is true.
For one thing, across the internet its never consistent. Sometimes its 4x, other times 5x or more.
Second, rotational mass would affect how quickly the revs can climb in a car, making the engine feel more responsive, but the engine won't have a more effective torque or hp delivery. That's not how it works with a light weight flywheel, it just means that the engine revs more freely. If your HP delivery is more peaky at the top of the RPM range, maybe it means you get there faster, but you also fall out of it faster.
Based on this testing from Car and Driver. a 14lb per corner weight difference (56lbs total weight drop) only accounted for a 0.3 second improvement in 0-60, and a 1 second improvement to 100. But.... the car is also nearly 60lbs lighter, and the tire & wheel package is 2% taller between the 19inch and 15inch. So, how much of that improvement is based just on weight and not "rotational weight" combined with a slower accel from 2% taller tires?
Unfortunately this isn't a full test, where it would include (in my mind) a mechanism where you could isolate the weight to just rotational weight gains. Which would be to either remove weight from the car for the heavier wheel package or add weight back for the lighter ones. Regardless, it proves there is VERY limited gain to be found, especially as the Emira several seconds faster to 60mph, which makes each 1/10th of a second harder to achieve.
That’s another reason that drove me to aftermarket tuning. It happened to me on the test drive and I wasn’t at redline I saw it. So I thought it’s a demo car bla bla bla. Got mine and when I finally let it rip happen to me and it is dangerous especially if your going fast on a long bend it really unsettles the car being mid engine.Feels relevant to the topic at hand, but regardless of swapping ECUs / tuning / raising the limit for more power or not, one thing that I could maybe talk myself into addressing via aftermarket tuning is having a less aggressive limiter... the stock behaviour is dreadful and almost dangerous. That right there essentially "robs" you of some top end, because you can't even give it the full 6800 without it throwing its hands up and hard cutting the fuel, so you tend to shift earlier to give it a wide berth (or at least I do).
That aside, I don't feel particularly aggrieved about the power or power delivery otherwise. And apparently it's ok to have different opinions.![]()
Yeah I can agree with this. The first time I hit the limiter I actually thought I'd hit something, it was so violent and sudden. This is something Lotus should definitely fix by making it a softer reduction.That’s another reason that drove me to aftermarket tuning. It happened to me on the test drive and I wasn’t at redline I saw it. So I thought it’s a demo car bla bla bla. Got mine and when I finally let it rip happen to me and it is dangerous especially if your going fast on a long bend it really unsettles the car being mid engine.
It's not. You can do the math and get real values. For my S5 assuming 5 lbs saved at the most beneficial point on the 19" wheels, it was equiv to 7.5 lbs of non-rotational weight. That was for a 2nd gear pull. First gear with higher rotational acceleration would be larger, third would be less, etc. Quoting a 1.5 factor (or lower) doesn't sell products.I just don't think the rotational mass myth is true.
