Did lotus rob us on horsepower?
Did another launch today, at 4000rpm, warmed up and ready for full blast. The weather was cool in the 20ies. I have cut the video exactly from 0-100 and the time is 6 seconds. I have titanium exhaust, air filter changed, short shifter and back on the stock ecu now however I have dynoed my car before so the numbers are correct… i have not an underperforming engine. I challange you guys to make a video where you hit 4.3 seconds on a manual!
  • video-2230_singular_display.mov
    14.1 MB
Did another launch today, at 4000rpm, warmed up and ready for full blast. The weather was cool in the mid 20ies. I have cut the video exactly from 0-100 and the time is 6 seconds. I have titanium exhaust, air filter changed, short shifter and back on the stock ecu now however I have dynoed my car before so the numbers are correct… i have not an underperforming engine. I challange you guys to make a video where you hit 4.3 seconds on a manual!
Was that a lift off or a first change where the revs reach just under 5k? The gear indicator seemed to be lagging.
If it's a first change I bet there's a bit to gain there.
I really thought those kids were going to cycle into your path, scary!
Im on the main road and they are on the sidewalk/side road there is no way they can come on my way although there is a crosswalk there is no path on the other side but construction.. don't worry I am a responsible driver 👍🏼 If you live here you know how the roads work..
It was from stand stil, kept the rev at approx 4k rpm and launched it, the car was slipping slightly as the tyres were not fully up to temp hence you saw it was hesitant a bit between 4-5k and once the grip was there it started to pull.. didnt go too close to 6500rpm into second as the wall is right there ready to slam your face.
I hit 4.39 but it was around 50 degrees and the road cold and not ideal. I was spinning for at least half a second or so it seemed. Once it warms up I’ll redo it and I think I should be able to hit 60 under 4 or right at it with how I’m set up. I’ll post results when I do which will be a bit.
Worth noting. Manufacturers will give themselves the most generous interpretation of the measurement. Unless they state otherwise I assume Lotus is including a 1ft rollout.
For those who care what the real world implication is.
I think it was Mark Twain who once said "There are lies, damn lies, and statistics". Regardless of what the numbers on paper are, once we get warmer weather, I'm going to do some Dragy runs which will measure actual 0-60 times on the street. I'll do two runs on the same stretch of road, one in each direction to eliminate any advantage or disadvantage of slope, and post those actual readouts. I want to do that with the factory iron brake rotors, and then the same thing after I install the CCB rotors. If anybody else has a Dragy, it would be nice to get some comparisons, especially for manual vs auto, and V6 vs i4.
I have a Dragy and will do the Automatic runs in the spring
Same. My 4.39 was with a draggy, on a cold day as stated above. I’m not stock thou with the 440 JUBU so will be interesting to see everyone’s best numbers. I will be going with the 460 JUBU probably late spring early summer so will do times on the 440 first then the 460.
Here‘s a comprehensive comparison:
4,1s for 0-60mph.
Porsche 911 Carrera T manual is £111,300 before options in the UK, 0-60 in 4.5s. I don't place much value on 0-60 figures as 30-70 is much more meaningful in real world driving, but another interesting comparison nonetheless :)
I really couldnt care less about 0-60 times, within reason. Sub 5secs is more than enough. After that, I just want power/torque is the areas I need it for real world driving.
An improvement in the 30-50, 40-60, 50-70 zones/times would be of far more interest to me
If you're unable to achieve the 5-60 time as tested (4.7s for v6 touring), it's either driver error or an issue with the vehicle.
Yes, I posted this video just to show that it can be done. To launch the Emira and get those times. Abusive use of revs is a killer recipe for drivetrain and clutch.
For me personally it is much more relevant to have those figures like 100-200kph. I managed to get 11,2s with my Emira, my old 2016 M2 with HJS downpipe and Wagner intercooler is faster. It's the torque over the rev range which makes the difference.
But there is so much more to it, like the instantenous throttle response of the V6 and of course the sound.
In the end I would sometimes also like to have more ooomph. But I'm really torn, I will have to visit Komotec and drive their test mule with the 475bhp setup. But to be honest I think I know already how this will end... :sneaky:
If You have money you can make any car what you want it to be...But then at that point you should just buy the car that has the Horsepower you want
