Emira Review Index [V6 FE]
    Featured
ReviewerTypeDirect Link
EdmundsArticle
Published 20th June
EvoArticle and Video Review
PistonheadsArticle
KHTVVideo Review
The DriveArticle
AutoExpressArticle
Pictures:
WhichCarArticle
CarBuyerArticle
HagertyArticle
GoodwoodArticle
MotortrendArticle
DriveArticle
AFRArticle
ParkersArticle
CarExpertArticle
Caffeine & MachineArticle
Photos on Instagram:
Car and DriverArticle
The SunArticle
two carry on cases fit easily on the back shelf of the Emira with a little room for a squidgy bag in between (someone posted a photo or two of this on another thread)...and that's before you use the trunk
Here it is:
Ah, but I was referring to check-in sized suitcases. :sneaky:
I've been waiting for this one and watching now. Seems very positive so far, but Matt was wrong about the springs being the same for both Tour and Sport options. We know they are different rate Eibachs, same Bilsteins.
Not the same Bilsteins. Different valving for each variant, which is where most of the difference in feel is coming from.
That's another story,
I am not sure any sports car this size will fit check-in size apart from behind the seats. in the Emira, If you are traveling alone, one full size luggage will fit behind the passenger seat
You sure? I thought it was just the springs. Remember when Harry toured the assembly line and there were boxes of springs separated by Tour and Sport?
Maybe you're right.. Harry says the shocks are labeled sport and tour, but it's still unclear to me if they're actually different or if that's applied once the springs are on.
It's around the 6m26s mark:
It’s not completely confirmed but they should be different. The difference would be in the valving. That can involve different internal parts.
I would expect that the sport dampers have a more digressive compression valving than the touring which means that at low piston speeds the damping ramps up rapidly. This makes things like turn in sharper but has a bit makes the ride a bit more jarring.
They do that by changing the physical piston in the damper to one of a physically design. Likely also requires a different shim stack and valve preload.
We won’t know till someone puts both dampers on a dyno or takes them apart :)
I'm 100% sure. There's literally no way to get the ride and handling difference between these two variants with just a change of spring. The vast majority of the difference in feel is the damper valving.
Or simply look at part numbers for the shocks.
It’s not quite that simple. You could for example increase damping by changing the shim stack preload by torquing it down more. No part difference could be present but they might put a different part number to differentiate the setup.
The point of confusion was if there was a hardware difference between the two setups. Part numbers don’t tell you anything about the actual difference. Like I said, we really can’t know without opening them up and/or testing them on a shock dyno.
Well we still aren't sure if the swaybars/endlinks/bushings are the same between both. It could be many things. It would make sense for the dampers to be unique though...
It'd be nice if these things could be confirmed by Lotus. I suppose someone could call a dealer and check part numbers.... 🤔
On the Sport set up it is worth listening again to Henry Catchpole's review from 3.30
Unlike the Smoking Tire duo, he'd actually bothered to do his homework before holding forth on YouTube :) The springs on Sport are less than 10% stiffer front and rear, but the dampers have more compression and low to mid rebound damping. I believe the bushes and ARBs are different too, although that isn't mentioned by Henry
My experience of 1100 miles in my Emira with Sport suspension is that it feels much firmer than the the relatively small increase in spring rate over Touring would suggest, so I guess most of that is down to the damping.
TST posted an update saying that a dealer gave them bad information. Unsurprising, they should have known better -- US dealer information is laughable.
It really is and I'm not sure what the issue is here. It's either Lotus HQ just not caring to communicate with US dealers for some reason or maybe it's Lotus of US failing us? I don't know exactly what Lotus of US actually does besides the roadshow tours and I suppose they'll be handling future warranty claims? They certainly don't communicate with dealers or customers at all... My dealer has expressed many times how frustrated he is with their lack of updates and transparency. Makes me dread potential (inevitable) warranty work.
Dampers have identifying stickers as per previous Lotus practice.
This is my sport front damper.
V6SF deciphers as V6 Sport Front.
Tour equivalent will be V6TF.
Rears are side-specific. V6SRL and V6SRR.
We are pretty darn sure, because Gavan Kershaw said explicitly that the dampers and springs were both unique to variant, and the other components were not. It's been in several interviews.
We also have pics of delivered cars in each variant, as above.
That's right the springs and dampers are different for Tour and Sport. ARBs and bushings are the same, as are the wishbones. Suspension geometry settings are different.
I could be wrong, but I thought that the geo difference was linked to the tyre selection and not the chassis type?
So Cup2s get the more aggressive geo (that suits that tyre) and Goodyears get a different geo (on both sport and touring chassis).
It's likely 3 different geo setups, not 2.
