The A/F ratio is what I'm going to be looking at with the dyno tests that
@GRP does. If the Eventuri delivers at low rpm what their dyno indicated, that shows that the supercharger isn't getting as much air as it can use through the stock filter system. It's not bad, just not ideal. Obviously at higher rpms it needs even more airflow which is where the less restrictive air filters will come into play.
The ability to deliver enough air fast enough is what's going to make the difference. The intake valve is only open for a fraction of a second, so delivery speed is important. The supercharger can only deliver what it can get from the air intake box.
It's like a dozen people trying to get through one door. If they all try to do it at the same time, they bunch up and it slows down people getting through. Pressing them all together from behind isn't going to get them through the door any faster either, the flow pattern has to change. If they form into a single file and work together, they can get through faster. The room hasn't changed, the door hasn't changed, and the number of people haven't changed; what changes is organizing their movement pattern so they can get through the door faster.
The stock air box is 'bunching up' the air into turbulence which is slowing down airflow through the filter. This isn't unique to Lotus; pretty much all factory designed air boxes do this, which is why aftermarket companies are able to slightly improve performance (sometimes) with their intakes. There are usually compromises though compared to stock, typically noise level and often exposure of the filter to the elements by not enclosing it completely like the factory system does. OEM's have gotten much better over the years with their intake systems in order to comply with regulations and emissions requirements, but there's still some room for improvement.
We'll see how the test goes and what the results are. If the Eventuri is the only one that shows improvements immediately, while the less restrictive filter element and whatever other systems GRP tests don't come into play until the upper rpms, that's going to tell the story. In essence, the Eventuri will be directing the airflow into a single-file pattern which will allow more air through faster. Of course the dyno shop is going to have blowers aimed at the intakes, both the engine intake and the radiators so each system tested will have the same conditions. They have to to prevent overheating and blowing things up as well as simulate a vehicle in motion.
