For an extra charge ( or not)Did your Emira come with a battery tender?
My Evora GT410 Sport (2019) does NOT come with trickle charger.The Emira (at least mine) did NOT come with a trickle charger!
My Evora came with one, I believe all Lotus of the last generation did. But the Emira did not have one. It comes with a tire repair kit and a tow hook.
The Evora definitely needed it in my case. But probably because the GT430 has the small Lithium Ion lightweight battery and I installed a tracker in it which sucked the battery (nearly) empty in about 2 weeks when sitting in my garage because it doesn't have mobile signal down there.
Not sure how the Scorpion tracker in the Emira will handle this.
@Dabjbr
Yes, I would say it is not centered over the transmission tunnel but shifted to the right (judging from one of the photos on my camera roll, I'm on vacation for a few weeks and haven't got the car around)
I took a photo today - the infotainment screen is significantly shifted to the right...
Does the Emira have any 12v sockets that are constantly live - that can be used to plug in a trickle charger?The Emira (at least mine) did NOT come with a trickle charger!
No, That was true for those Evoras that had a 12V socket in the boot, but later models didn't have that and the Emira internal 12V is switched with the ignition.Does the Emira have any 12v sockets that are constantly live - that can be used to plug in a trickle charger?
Very lucky to have a yellow car cause it will turn yellow in about a year lolPosting from another traffic jam on very busy Ring that just got temporarily closed when I arrived.View attachment 10277
Here is the PPF'ed area, its as far as I have seen the only section on the car that has factory PPF.
yes...its only the lith. ion light weight Lotus's to my mind that came with a trickle charger..and I for one am glad the 10 kilo weight saving is overlooked for the practicality of not having to plug the damn thing in all the time, which sometimes is not feasible...My Evora GT410 Sport (2019) does NOT come with trickle charger.
most I left it in garage was 3 weeks and no issue at all. Of course it's not the lightweight battery, so I think we should have no issues with Emira.
Guess we will not find out until winter hits, since you fortunate early drivers are not letting it settle for more than a few days at this stage !!!
I live in the US capital of the sun.....When ever you can afford it, have a reputable installer do it right with a good warranty, mine gives me 10 years, I did my Range Rover and I'm waiting for some Carbon parts to do my GT next@RENDERMAN depends usually on the type of PPF. On my Evora it lasts already for 4 years without turning yellow. But then I also have to say it doesn't stand in the sun a lot.
Demo car I drove had a hook up for a trickle charge and the dealer told me it came with it.
