I4 (AMG-2.0 Turbo) DCT gearbox software update from LOTUS - mid August 2024
There is a software update that seems to have been released by Lotus for the gear shifting algorithm of the Emira AMG-2.0 Turbo. This may improve the perceived delays when using the flappy pedals, and it is said to even improve going from forward motion into reverse. It will be interesting to hear from owners, that gets this installed, about the extent and subjective feel of this update.
Did anything more come of the software update for the 40bhp increase?
Anyone know what the software version is, if its actually a thing?
Car goes to the shop on Wednesday and if there is an upgrade, I want it :)
Got my car back and pparently all updates applied. Power bar still tops out at 360 :(
Does it feel the same though.... the bhp on that power bar may not ever show the correct hp. It may only go up to 360 even when your running 500hp, as it could be linked to throttle position (for example).
The power meter is certainly calculated, however it's probably relatively close.
You can put this to bed for ~$100. Just buy a Draggy performance meter, the new ones are very easy to use and pretty accurate (with a level test area) .
360 Hp with a small driver (150lbs) + launch control on a cool day should yield ~4.2 sec to 60mph without rollout
400hp same conditions ~3.8 seconds
