Just purchased the Milltek Valve controller. No instructions were included in the kit whatsoever, not even a url. Dose any have actual instructions from Milltek they can post?
Found this on the GRP site, a bit concerned about button 2 vs 3. Does it come configured to start in last set position ?
The controller has three buttons:
1- Valve open 100%
2- Valve closed 100%
3- OEM valve control -- valve runs just as it does stock.
Some controllers have been reported to have #2 and #3 opposite of this. The best thing to do to verify is start the car, put it in sport mode and then while next the exhaust outlet press #2 and then #3. See which one closes the valve and which one keeps the sound the same.
A couple of programming options as noted from Milltek:
The valve remote can be programmed to change the start mode.
If you want the vehicle to start in the last used mode you need to press button #1 5 times within 5 seconds.
If you want the vehicle to start in a specific mode you need to press and hold the relevant button for 10 seconds.
The flaps will open and close 5 times to confirm the start mode programming.
Are you able to inspect the valve position with a 3 ft wire camera probe or are there too many bends (AMG engine) ? (Not supposed to put car in Sport; still in break in period)
