SweptVolume
really surprised... that wasn't my experience in the demo car today at allRadio 1 point of 10, streaming 3 points of 10![]()
Not my experience either. Test car stereo sounded great to me.really surprised... that wasn't my experience in the demo car today at all
Eager to see a reply to this. Very good comment.Really odd that the the review differ so much. @Speedluvver for example has heard the big 6k Burmeister system (which is probably one of the top 5 systems out there) as a reference and says it's not quite there, but still very good. @1stczechemira on the other hand says it's worse than a cheap bluetooth speaker.
This seems very strange to me, because I believe both of you and you both seem to have some experience with different systems. Maybe they used the old amp in you car @1stczechemiraor it has something to do with software and you are running an older version which KEF and Lotus addressed again after the initial bad reviews of the system.
My grandfather had something like (see photo) in his Skoda S100 in the 70ies and the sound was better...
(The Skoda S100 was a rear engine and rear drive car - a "Porsche" made by then state owned Skoda)
View attachment 10387View attachment 10388
I think someone said you cant.....I didn't try with putting more sound towards the back of the car, that may simulate more bass to the ears.
Im sorry, but ANY use of "bullying" cannot be tolerated .. And I am "resigned" to say, not even in a speaker "cabinet"...@Eagle7 thanks for following up this with KEF. I am a big audio fan and build my own speakers and hifi components etc. While not a big listener in cars strangely I do appreciate a decent sound there. It is a horrible environment to get true HiFi and have tried many times over the years. The only success is with high power and bullying the sound out of the speakers, usually at high volume. I look forward to anything comments you recieve.
My main cabs I built for home use
If you are still let down by it, then it must be worth raising it with your dealer and asking, does it have the upgraded amp and latest software and hope they can actually check with lotus and lotus actually know.Ok, after your comments I'll give the system one more chance...Tomorrow I'll have some more time to test it comprehensively. Then I'll post again. (Maybe there is something wrong with the system just in my Emira.)
Very well written. And considering the system updates can be done without a trip to the dealer...makes it a non-issue to me unless I'm missing something?@Israel_7 me, too. The speakers are driven by DSPs, and the programming of those can ruin everything. The DSP assigns the correct frequency spectrum to each driver, it corrects every drivers frequency response with eqs, adjusts the different distances from each driver to your ears with different timing delays, and much more. Think of it as the sound systems ECU. If you stick the AMG 4 pot ECU to the Toyota engine, the 2 GR would probably also not behave to our likings.
My number one guess would be that there are different DSP setups out there, which would be easy to correct with a software update. But I also wouldn't wonder if they used the old amps they had laying around to make them disappearNevertheless it sounds odd to me that there ever was such a bad setup to begin with. Even with the less powerful amp it should work just fine, you only need more power for the last few decibels in volume. The new amp will probably result in 2-3 db more volume. It has nothing to do with sound quality however.
Looking forward to your follow up, and thank you for taking the time to find out.Ok, after your comments I'll give the system one more chance...Tomorrow I'll have some more time to test it comprehensively. Then I'll post again. (Maybe there is something wrong with the system just in my Emira.)
A simple thing like reversed polarity could kill it all. It would result in a phase shift of 180 degrees and therefore one driver would do the exact opposite motion of the other. If one of the mid woofers is shifted in polarity, it would just obliterate the others frequency response. That's the effect used for active noise cancelling. And the mid woofer could also impact the subwoofer to some degree as well, because at and around their respective crossover points, they are working together.Reading all this, I am getting the feeling there may be quality issues in some of the wiring looms, like reversed polarity... Might be good to have your dealership take a look.
What surprises me is the lack of conversation about the speaker placement in the Emira. There are just simply no tweeters on ear level. I get that KEF has the Uni-Q "feature" but what's the point in sending the high frequencies to my kneecaps?! Adding to this, my car clearly has speaker preparation in the front pillars, but nothing installed in them! Future upgrade or are we missing speakers?!
The KEF system is stated at 10 channels, not speakersDon't want to call myself an audiophile but I have a very decent home setup and also experience with quite a few other high end car hifi systems. The KEF is not _that_ bad. In my opinion, it lacks power but the sound quality itself is good for a sports car. They often lack room inside the cabin to make a system sound great. Thats a problem they all have. The bigger the cabin, the better the sound will be.
For example, I had an F-Type with the insanely expensive (was it 5k?) Meridian "surround" system and it was worse than the KEF in the Emira. The middle level Meridian in my girlfriends Evoque in comparison was one of the best I've heard (on par with eg. Bowers and Wilkins in an Audi RS4).
Unfortunately still on vacation so I can't take a close-up of it, but there is 100% an empty tweeter opening behind this metal grill.
EDIT: Ok, just saw that it was actually mentioned in the first post of this thread. Base system will have tweeters in A pillars.
I still wonder where the 10 speakers of the KEF should be though.
https://uk.kef.com/pages/uni-q. Some info here….There aren't any tweeters on the A pillar bases?! Why would they have tweeters for the base spec audio but not the fancy expensive KEF system? That just seems silly.
