Good eye. I wonder if the change over to the new style caused the supposed shortage.That’s a new battery tender style
Jackery seems to be the best.Anyone have a recommendation for a portable 'Power Station' that can fit in the trunk and power the trickle charger?
How is your side mirror broken?My car didn't come with the charger. I've been using a NOCO trickle charger. I need to take my car to the dealer for a broken sideview mirror, might bring that up to them.
No clue. I have it set to fold in the mirrors when I lock in the door and a few weeks ago, I noticed only the drivers' side mirror was folding in. If you touch the passenger side mirror, it feels loose as if it isn't properly secured. No scratches or impact to mirror that I'm aware of.How is your side mirror broken?
this isn't accurate. My Emira came with the trickle charger, but it wasn't wired to the battery. The new owner has to do that on their own.FYI, charging plug is now factory installed. Along with a Lotus branded charger. There are also velcro straps on the left side to secure the tire service bag, kinda hidden away.
Magma color looks great under 6000 k lights
My car did the same thing shortly after I got it. After driving it a little and opening and closing the doors, it self corrected. 3 months later, it has not happened again. Gremlins?No clue. I have it set to fold in the mirrors when I lock in the door and a few weeks ago, I noticed only the drivers' side mirror was folding in. If you touch the passenger side mirror, it feels loose as if it isn't properly secured. No scratches or impact to mirror that I'm aware of.
Mine is clearly broken. Definitely not an electrical issue.My car did the same thing shortly after I got it. After driving it a little and opening and closing the doors, it self corrected. 3 months later, it has not happened again. Gremlins?
Would the charger connect directly to the battery or is there a supplied connector which allows to connect to the chargingFYI, charging plug is now factory installed. Along with a Lotus branded charger. There are also velcro straps on the left side to secure the tire service bag, kinda hidden away.
I looked at the charger briefly, it doesn’t look like the charger will connect to the pre-wired charging cable directly, is there an adapter of some sort?FYI, charging plug is now factory installed. Along with a Lotus branded charger. There are also velcro straps on the left side to secure the tire service bag, kinda hidden away.
