I have privacy glass and can see the engine fine through the glass. That video is a bit misleading as it depends on the angle you are looking through the glass.Even though its NOT exotic, wanna see the engine.
Does the heat from the engine not cause the tint to bubble? I went to tint mine and the tint company stated that it would not last long due to the engine heat. So since the little behind the seats to see into the engine compartment, I tinted that instead so that people are not looking at the back of my head.![]()
This is a Nimbus with privacy glass. Depending on the angle you look at the engine the glass can look darker but you can definitely see it.
My car came with the "Privacy delete"Factory tint is embedded within the glass. It can withstand the heat.
Agreed. The engine is very visible even with privacy glass.
My car came with the "Privacy delete"No Privacy glass.
Yes. This statement(above) is accurate. By checking Yes you are confirming that you wish privacy glass to be deleted from your configuration. Many are wondering why it wasn't: check yes or no for privacy glass desire.Needing clarification. On order form from Lotus, line 30 reads Privacy Glass Delete. If (Yes) is entered it means you will not be getting the Privacy Glass and if (No) is entered it means you will be getting the Privacy Glass. Is this correct?
Thank you for the clarification.Yes. This statement(above) is accurate. By checking Yes you are confirming that you wish privacy glass to be deleted from your configuration. Many are wondering why it wasn't: check yes or no for privacy glass desire.
Not sure of your preference but I have Privacy glass and visibility aft is more than adequate. It matches the black surround trim. As far as I can glean, anyone wanting to feature the V6 engine skips Privacy. The i4 has a different somewhat bland in comparison appearance.
Upper black pack is a whole other debate.
Choose what moves you.
