Removal of fugly warning stickers on Sun Visors?
I removed mine by soaking cloth in 99% wiping alcohol and covering with plastic bag. No glue was left behind but be patient and wait a good 15 mins or so to sully release the sticker.
Maybe in the UK the stickers are attached in a different manner. U.S. stickers do not come off when they are soaked in alcohol, or other solvents. We used to be able to get these off, but I'm sure our government enacted some program to ensure they are extremely difficult to remove.
As Rapture mentions above, the stickers in the US are mandated to be "permanently" fixed by federal regulations, to ensure (or make it practically impossible) to remove them without damaging the visor, so in the US, most of these stickers are practically baked into the visors. I happen to also own a car in Europe where I've removed the corresponding warning stickers using a light solvent w/o leaving a trace.
For anyone interested, I covered my visor labels and I'm 99% satisfied.
(Trimmed)
Hope this helps others.
Very helpful, thanks! I’ve got some Alcantara on order, just need to pick up some adhesive.
I’m a fan of 3M 77….but are there any thoughts on whether this is the best for Alcantara? (I’ve never worked with it before)
I suppose my use of the 3M 77 with alcantara, hasn't yet passed "the test of time", however it looks good so far. It's meant to glue fabric, so I assume it'll be OK.
One more dumb question...
Any tips for Visor removal?
Do the little plastic bracket covers just pop off with a trim tool?
Thanks!
Thanks!
Yes, the plastic cover just pops out with a pry trim tool. Once you remove the screws that secures the visors to the roof section, they essential pop out as well. In case you haven't done so already, take a look at the pictures posted by one of the members at the beginning of this thread, particularly of the visors' hinge sections, which ought to give you a visual of how they are embedded and secured. The one thing to be cautious with when extracting them is with the passenger side visor's mirror light wires. Remove that one slowly and allow enough slack to disconnect the wire harness before pulling it out completely.
So I finally got around to doing mine.
Had some patches laser cut out of Alcantara, and cut also cut a masking template using a Cricut so I could get a 2-sided bond without any overspray.
Thanks again for all the info in this thread!
Looks much better, can I ask where you had the alcantara patches laser cut? Cost? Did you use the 3M 77 adhesive mentioned previously in the thread?
I had a local sign making shop cut my material from my files drawn with AutoCAD. I wouldn’t recommend them and would look elsewhere unfortunately.
Yes, I used 3M 77 on both sides and it worked great.
Personally, if I was going to do this, I'd probably look into running the alcantara in a strip covering the sticker but have the edges folded over and stitched to look more intentional
Looking more like a "stripe" down the center of the visor, not a flap that perhaps has a mirror hidden behind it.
Not a bad idea, but actually I’ve been surprised of how the alcantara patch over the stickers makes the visors so unnoticeable.
Given the light level in the cabin and the texture of the Alcantara, they really do just go away… Super nice to not have the distracting patch overhead!
Probably the only real solution here is to have a trim shop recover them, but I didn’t want to drop that much coin.
