- Joined
- Aug 10, 2021
- Messages
- 6,427
- Reaction score
- 14,655
- Location
- Surrey, UK
- Emira Status
- Emira on order
Yeah, a spokesperson/designer/someone at Lotus said the Emira is lower on power because of stricter emissions regulations now.
Regarding weight and 0-60... I'm in the US, so comparing it to the US 2021 Evora GT:
1. The Emira is actually lighter at 3,097 lbs, whereas the 2021 Evora GT is 3,175 lbs.
2. The Emira is significantly slower in 0-60 at 4.3s, whereas the 2021 Evora GT is 3.8.
I'm kind of expecting the Emira to be overall faster around a track than the 2021 Evora GT, having the weight, aero, and suspected chassis/suspension advantages.
On another note, I thought I read that the only white Emira in existence is the 4cylinder. I sure hope they don't test the 4cyl on Top Gear...
Yes, the Evora GT only had to meet US emissions whereas the Emira is a world car and has to meet regulations for every country where it will be sold. So Evora GT 416hp and Emira 400hp.
On weights, your 3,097lbs for Emira is for the i4 with no options. The V6 FE is 3,215lbs but that's EU DIN weight not curb weight, so you need to add another 165lbs = 3,380lbs curb weight. So the Emira V6 FE is 205lbs heavier than the Evora GT - not surprising given there's $10k of carbon parts on the GT and the Emira FE includes those heavy seats and extra tech
The Emira will be slower 0-60 - more like 4.3s versus the GT's 3.8s (but no one actually achieved that and 4.0s was a real world figure). I agree on track the Emira will probably edge it, depending on the track. It has a wider front track, improved suspension setup and better aero including more high speed downforce. Anecdotally I understand the Emira is faster around the Hethel test track than all Evoras except the GT430.
I believe there may be two white Emiras. I've seen the spy shots of the muddy one with the ADAS sensor pod which we assume is an i4. The one we saw at Hethel I was pretty sure was a V6 and had no sensor pod. Perhaps TG are going to test both?
