Featured
- Thread starter
- #161
Yellow vinyl over the ppf.Is the stripe painted or did you use pinstripe tape?
The color is closer to the Lotus logo than to the yellow calipers
That looks great fro those that didn't choose colored calipers, and specially without the black pack, gone for classy vs sporty.I've been playing around with additional versions to tone it down some for those that don't want something so dramatic. Here's an idea with medium gray for the stripe, and the LOTUS letters outlined instead of solid.
@Eagle7 you are really a photoshop wizard, or whatever program you use to do your renders. Most impressiveI've been playing around with additional versions to tone it down some for those that don't want something so dramatic. Here's an idea with medium gray for the stripe, and the LOTUS letters outlined instead of solid.
A wonderful reminder of that beautiful country and those incredible roads
absolutely. the more I see it the better it looksThose yellow pinstripes look great, and the car looks so at home. Happy to hear the ownership experience is good, mine is too.
Thank you. I use a 3D modeling program called Cinema 4D from a company called Maxon. I bought the 3D file of the Emira online, and did everything else, including all the paints, colors and textures. Here's a quickie of a DV with a thinner yellow stripe and the LOTUS letters outlined. It's slightly more subtle than the one I originally had created. The stripe and LOTUS are in the factory yellow of the logo.@Eagle7 you are really a photoshop wizard, or whatever program you use to do your renders. Most impressive![]()
I have also used cinema 4D a few years ago, where did you get the models?Thank you. I use a 3D modeling program called Cinema 4D from a company called Maxon. I bought the 3D file of the Emira online, and did everything else, including all the paints, colors and textures. Here's a quickie of a DV with a thinner yellow stripe and the LOTUS letters outlined. It's slightly more subtle than the one I originally had created. The stripe and LOTUS are in the factory yellow of the logo.
Here ya go: https://www.cgtrader.com/3d-models/car/sport-car/lotus-emira-2023I have also used cinema 4D a few years ago, where did you get the models?
What size are the letters - about 50mm high?Thank you. I use a 3D modeling program called Cinema 4D from a company called Maxon. I bought the 3D file of the Emira online, and did everything else, including all the paints, colors and textures. Here's a quickie of a DV with a thinner yellow stripe and the LOTUS letters outlined. It's slightly more subtle than the one I originally had created. The stripe and LOTUS are in the factory yellow of the logo.
Probably somewhere between 2-3 inches (50-75 mm). Without having an actual car to make some measurements, I can't give you an exact number yet. Once I get my car, I'll make a template and post it up online for those that want to do this.What size are the letters - about 50mm high?
@Bilbao-Emira how did you have your Gopro mounted for your Mountain 1 and 2 videos?
My co-pilot holding it with the stick@Bilbao-Emira how did you have your Gopro mounted for your Mountain 1 and 2 videos?
