KJWEmira
Agreed - here’s mine after 3600miles, no leaves thoughIt’s definitely a concern. I was surprised by how much crap was inside the intake box after only a few thousand miles, including plenty of leaves.
![Winking face :wink: 😉](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f609.png)
If you’re referring to replacing the filter in the Eventuri then you have to remove the entire Eventuri. However, this is easy & simple because it’s simple to unbolt, & comes out of the space easier than opening the standard air box IMO.I wonder how difficult it will be to replace the air filter in these![]()
The weather was NOT the same. For the baseline run it was raining that day, and I literally drove through the rain to the dyno shop. Temps were in the high 70's. Today we're in a heat wave. It's currently 106 and this morning it was already 91 when I had my dyno run.Can we get the uncorrected dyno charts please? Your two pulls are showing different SAE correction factors, which is unusual considering the weather is almost identical. It may be automated based on a weather station "accessory" with the dyno, but it's hard to say whether the correction factor is correct without knowing if it's been calibrated recently.
To avoid doubt, there should be a way to switch the view into uncorrected mode, which would make the absolute values less "accurate" but increase the fidelity of the comparison between the two runs, which is what most of us care about.
Which is going to be in the freeer intake as well. I wonder if someone's going to make a large particle screen for the intake.It’s definitely a concern. I was surprised by how much crap was inside the intake box after only a few thousand miles, including plenty of leaves.
Well something weird is going on with their sensor pack then, because the two runs show a nearly identical barometric pressure. That's super unlikely in the scenario you've described.The weather was NOT the same. For the baseline run it was raining that day, and I literally drove through the rain to the dyno shop. Temps were in the high 70's. Today we're in a heat wave. It's currently 106 and this morning it was already 91 when I had my dyno run.
That's what I'm trying to determine. The SAE correction should normalize the runs to the same values regardless of weather. But in this case the numbers raise questions.Isn't the difference just the SAE factor though?
I’ve raised this question among some friends who should be able to supply an answer.
However I feel we should accept this on face value for now.
The dyno shop has no skin in the game - they didn’t supply or fit the intake.
Why would they fudge the numbers?
This is also in line with what Eventuri - by all accounts a perfectly reputable company - claim.
So why the scepticism?
The OP appears to be doing all of us a favour by doing exactly what we’d want anyone to do re a performance mod. Independent before and after tests.
In the absence of anything concrete to the contrary I’m prepared to believe the gains are real.
Yeah agreed - to answer my own question, if the atmospheric numbers were measured correctly then the SAE change should be fine. They use the older formula, so my calculator won't be exact, but using the newer J1349, you get:Isn't the difference just the SAE factor though?
I think it could be mostly brake dust when you look at the photos of that used air filter element above...They all seem a bit high, but the correction makes no real difference by my maths! So looks like a good upgrade if it sounds OK and isn't sucking sand into the engine!
Ooooh, very good point! That would explain the black soot looking dust. I wonder if this additional mat was added specifically to filter out brake dust like this.I think it could be mostly brake dust when you look at the photos of that used air filter element above...
I don't know how to run a dyno, so I just trusted the operator to know what he was doing. It was the same guy, same dyno, so I figured the results would be representative of the actual gains the Eventuri provided. We're at an altitude a little over 2,700 ft.Well something weird is going on with their sensor pack then, because the two runs show a nearly identical barometric pressure. That's super unlikely in the scenario you've described.
If the dyno is indoors I can see the ambient temperature being almost the same, but having the same barometric pressure in two very different weather conditions would be way unusual. Is the dyno in an air conditioned space? Or was it warm in there today?
Also, if somehow they are coincidentally both the same barometric pressure, 26.99 and 26.94 InHg Absolute are both super low. Are you at altitude? I would expect a low value on a rainy/stormy day but not on a hot clear one. Even if you're somewhere high like Denver, I'd expect the clear day value to be substantially higher than that.
Performance mods don't add up like a calculator. The performance gain a mod claims to provide is based on nothing else being changed. As soon as you start changing other things, it's going to alter the results previous mods have provided. Sometimes that's good, and sometimes it isn't. This is why you should always change things one at a time, and make sure what you just changed is working correctly (or as you hoped it would) before changing something else. This makes it a whole lot easier to troubleshoot issues if there are any.This is all excellent information, thank you to the OP.
This may be a dumb question but I’ll ask anyway:
What would happen if you put in the Eventuri and did the 3rd cat delete and got a resulting, say, 20hp improvement overall, and then installed the Jubu 440 upgrade?
Are these things cumulative? Would you end up with more than 440hp?
Would Jubu have to adjust their kit to cater for the fact the other mods have already been done, and what do we think the result would be?
Now I need to find out how
If it is fine brake dust particles, would the Eventuri (or any other high flow filter) remove these before entering the engine?Ooooh, very good point! That would explain the black soot looking dust. I wonder if this additional mat was added specifically to filter out brake dust like this.
I don't think it's brake dust. You aren't generating that unless you're stopping or slowing down, and based on how it clings to the wheels and brake calipers, I don't see it making it's way up the side of the car and into the intake. To me that looks more like dirty water spray coming off the tires from the road when it has rained or is raining. If you're driving through overspray coming from the vehicles in front of you, that could possibly make it's way into the intakes on the side. That could possibly be why Lotus has that gauze on there in the first place, to keep moisture or flat out water from making it's way through the filter and onto the MAF sensor.If it is fine brake dust particles, would the Eventuri (or any other high flow filter) remove these before entering the engine?
I have been a dyno operator, which is the root of my questioning. I am not questioning that you saw gains from the intake! Far from it. It looks like a very legit product.I don't know how to run a dyno, so I just trusted the operator to know what he was doing. It was the same guy, same dyno, so I figured the results would be representative of the actual gains the Eventuri provided. We're at an altitude a little over 2,700 ft.
X | Naples Motorsport wants another deposit and adding Dealer Fees. Is the Dealer Fee a markup? | Lotus Emira Purchasing | 18 | |
Add lightness - reduce sales. Add weight - add sales & margin? | Lotus Emira Talk | 12 |
