luciddaydream
Hi there
Thanks a ton
For those who really hate the brake dust just be aware, as I stated earlier, it not all from the brake pads while I suspected the OE rotors might contain higher than normal carbon to achieve such an annoyed result.
You can replace the pad and see the difference first; or along with the rotor at the same time for an optimal result.
Its definitely good to have support from folks. I am sure to think of you for rotors when I am looking at some track activity. Might be good to have a dedicated set of rotors and pads.
Thank you~!
We are glad to be a sponsor of this forum.
See here for the most recent update on brake pads availability and how to pre-order them.
No you have total flexibility.
Our brake components are designed from a "system" stand point to maximize their potential while still fit their respective OE counterparts, so you can only replace OE pads, OE rotors, or both at your own path.
Just as a point of clarification, you're saying that your upgraded front pad in the different shape (as shown on the left of this photo) will fit the location of the original pad (pictured on the right) with the original caliper and rotors? So it's a factory compatible pad with increased pad area?
Excellent. Is the rear set similar in area increase?
A link to these products on your website would be awesome, if you're able to share.
Just for fun - Not Emira related is our brake development on the most talk about Cybertruck brake, the 410mm bbk fitment test was just performed today right after Emira's brake design was all cleared and released to production.
And a reaction from TRX after they learned we are making brakes for CT.
Rear is a lining based on D1346 for Nissan/Infiniti Sport 08-13 front.
  • FMSI Lining # 8457
  • Width (Depth): 54.6mm
  • Thickness: 15.9mm (Made ro 16.8 per AP caliper specs).
  • Length: 122.7mm
