Dashcam for the Emira
Well since I last posed, I am now looking at the A119 Mini 2.
Only very slightly bigger and has a screen, which I dont need, but may prove useful. And for the so small increase in size, most likely worth it.
Decision, Decsions
I run the mini 2 in the Emira and M2. Hasn't given me grief and has worked fine to pull footage of silly drivers on the road as well as a backup camera for capturing footage of driving on the racetrack.
I have the Viofo A229 Pro 4K which has worked with no problems so far.
You would think that that would use slightly more power than the VS1 so you will be ok.
If you do get the VS1 can you check if it is suitable for fixing to a vertical screen?
It looks like it should by the pictures on their website.
I was thinking about sticking it on the rear screen as a stand alone camera rather than having one attached to my front one.
I'm running a viofo vs1 up front, as I just wanted something small and unobtrusive, but with with good low light performance (and it was crazy cheap around Black Friday).
It is adjustable through a large range, so would work just fine as a rear facing cam.
I don't really care for having a screen, but the thing I do kinda miss is it doesn't support WiFi "station mode" like the viofo cams further up the range (which I use in our other car).
OK, have to ask.................. Whats Wifi Station Mode?
You can have the camera automatically join your home network when in range (instead of acting as a hotspot that you must connect to). Makes getting access to the videos convenient, as any computer on that network can get to them.
Edit: the real win is if you set up something that watches for the camera appearing on the network (i.e. as you arrive home), and automatically syncs videos onto a NAS. ;)
I'm now torn between the Kenwood A510W, or the Viofo VS1, or A119 Mini. Cant make my mind up.
The Viofo's do seem to have the better CMOS sensor though
I couldn't see an option on the Kenwood to have an anti glare polarizing filter whereas the Viofos do. Something to consider.
I also debated between the A119 V2 Mini and Kenwood, but opted for the A119 due to its smaller size, physical buttons below the screen and most importantly, for me, because it is easily detached from its GPS base facilitating any needed occasional removal. Most others use the rotating ball base which is not as practical for removal and prone to wear with time.
Sounds like you've got some good options. One additional consideration is the Maxcam 360. I hardwired mine into the rearview mirror for power supply reasons (thanks @silent cilantro and @kitkat) - the usb plug isn't enough juice - and I've been very happy with the combo radar detector and camera functionality in a tidy single package. Mine is mounted on the passenger side too for a more stealthy appearance. Yes, it's not cheap, but given you can use it for years and take it with you to your next car, it felt like a worthwhile investment.
Those are bonkers money over here. If I have it right, Amazon showing it for ~£1700 !!! Ten times what I planned on paying for the 3 mentioned earlier.
Can't speak to the prices in the UK (it's $850 USD), and you might not have driving habits like mine, but if it saves me from one speeding ticket, it pays for itself.
There are definitely more affordable options out there for those that don't mind a dual radar/camera setup.
Right, latest news. Kenwood is out. No Polarisation filter and Kenwood themselves dont know what CMOS Sensor it uses, so no way of knowing if it is as good or better than the Viofo options. Viofo use the latest Sony CMOS Sensor which is considered one of the best currently available.
So before I hit the "Buy Button" anyone else have suggestions other than Viofo, that are around the £140 price, 2K, parking mode, Polarisation filter.
I’m keeping an eye on this as I’ve never had a dash cam before, but think I’ll get one for my Emira. I’ll shamelessly jump on the back of your research! I like the small size of the Viofo. My only question would be, what are the downsides of it not having a screen?
I kind of look at it the other way around... what is the point of a tiny little screen that is awkward to look at (when I have a gigantic portable one in my pocket)?
The A139 Pro in the family car has been great, and it's nice and discreet, so you pretty much just forget it is there. The VS1 is also practically invisible to me (on the passenger side of the mirror pod), and doesn't get all up in the face of any passengers, which is nice too. I'd reckon the A119 Mini v2 would also be a fine choice, but I'd get it despite the screen, not because of it.
I'm leaning towards the VS1, given I plan to put the dashcam behind the Rear view mirror, on the passenger side and would not be able to see the screen for most of the time anyway.
Just hoping/wondering if others have opinions on other Dashcams I should have considered, before buying it
I have the A119 Mini V2. Works really well. All the positives have been mentioned: Small size, easy to detach from the base, etc. I also like it because the lens can rotate and be positioned to aim, plus there is an optional polarized filter for it. The video quality is excellent. I set mine so that the screen doesn't come on. I don't really use the interface for anything other than the initial setup. I always just pop out the SD card to play on a computer if I want to watch any of the videos.
Went with Apeman 420-D-worked on GT and now Emira powered by outlet on mirror pod.......have not run wire for rear view camera yet.........on sale now ~$51.00, maufacture website..............had to do some "fiddling" to get all functions usable.......sketchy instructions, but everything covered and all works seamlessly
You're not helping.....VS1, I've made my mind up VS1, VS1, A119 mini Do'h, VS1
  • Haha
Reactions: ADC
